Old 10-16-2005, 11:11 PM
Dennis ex24
how to adjust the idle speed on my SVX?
i have this intermittent stalling issue with my car now that the weather is starting to drop to cooler temps.
id like to know if there is a way to adjust my idle speed up because i think this will cure my problem. this usually occurs when all kinds of electrical stuff is going (lights, heat, etc.) when i come to a stop at a light.
Old 10-16-2005, 11:29 PM
THAWA
The only way to adjust the idle is to let the ECU adapt for it. You're better off trying to fix the problem than screwing up the settings on the throttle body (which offically once you touch it you have to replace it), IAC valve, or anything else.
Old 10-17-2005, 07:06 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Sounds like the problem is an excessive load on a weak alternator. Mean ole Mr. Inductance is dragging you down bro!!
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-17-2005, 10:12 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The IAC would compensate for alternator load as well as anything else.
p.s. I think you mean reluctance, not inductance.
Old 10-17-2005, 03:29 PM
wawazat??'s Avatar
Yeah, I'm still around
Like Dennis said, it has a reluctance to keep running Carl
Down to none
Old 10-17-2005, 05:12 PM
Beav's Avatar
Not as old as Randy
Use these words in a sentence:
"I went to Hooters in search of inductance but was only met with reluctance."
Old 10-24-2005, 05:33 PM
crimsonnblue
does the rpm ping back and forth?
Old 10-24-2005, 05:39 PM
Get your alternator tested and until you fix the problem keep a little on thegas at stops.
Old 10-24-2005, 07:42 PM
Dennis ex24
its not the charging system that is the problem.
i think it has something to do with the RPMs falling so quick now that there is a 5 speed in it.
i adjust the throttle cable slightly and the problem is gone. about a turn or 2 on the lock nuts and all is well.
Old 10-24-2005, 07:53 PM
Ah yes. The 5speed idle problem is quite common. Funny noone assessed that.
Old 10-24-2005, 08:41 PM
No... I meant inductance.
Robert
Old 10-27-2005, 11:36 AM
My 5speed stalling problem went away after I gave the throttle body a good cleaning with Mercury Powertune (some must have gone into the IAC to clean that as well).
