Old 07-22-2005, 12:40 PM
AvPPoW AvPPoW is offline
5 Speed (pedal box) question
I'm using 2002 2.5RS pedals, same as WRX pedals. From what it looks like, I'd be best off removing the clutch pedal and mounting it to the side of the SVX box. I'd be interested in pics if anyone has pictures of their modded SVX/WRX/Impreza boxes.
Thanks,
John
Old 07-22-2005, 12:42 PM
Is this for a hydraulic setup? If so keep the clutch/brake and just use the SVX gas pedal.
Old 07-22-2005, 12:49 PM
Really? So I don't even need to modify the box other than the screw holes that dont quite line up?
Old 07-22-2005, 01:03 PM
yes...almost
there are the 4 holes that bolt to the brake booster...those are fine.
the other 2 holes don't line up. You could easily weld on a plate to the pedal box so that you can bolt up the top 2 holes.
Solid pedals are happy pedals.
Old 07-22-2005, 01:36 PM
yes...almost
Cool, I see now. That makes it much easier than I thought it would be. One more question, what do I do with all the wires at the firewall hole? Seems like thats the best place to put the clutch master
Old 07-22-2005, 01:43 PM
that's the only place to put it.
Take a look at the pics I took during the conversion:
http://svx-iw.com/pics/5speed/
As for the wires, most of them will be pulled inside the car.
Old 07-22-2005, 03:05 PM
which wires can I pull? I assume they're for the tcu
Old 07-22-2005, 03:17 PM
That's the ones. The 2 large connectors no longer need to pass through the firewall.
Old 07-23-2005, 07:25 PM
Earthworm, did you have to cut your brake or mcylinder pushrod to get it to fit?
Old 07-25-2005, 11:34 AM
Definately. My dad cut it so I don't know how much he cut off. I think it's mentioned in Huck's writeup though.
Old 07-25-2005, 01:04 PM
That would be a nice chunk of info for those looking to do the swap. I have been thinking of converting to hydroulic so it is easier to go 6mt if I want to. But I like the cable clutch as of right now. Perfect for me to have absolute control.
Old 07-25-2005, 03:41 PM
Having driven yours (cable), mine (hydraulic) and my dad's (cable) 5spd SVX's both my dad and myself agree that mine is by far the easiest to shift/drive.
Old 07-25-2005, 08:33 PM
ah but simplicity comes at a cost. i feel I have much better control over my clutch than I ever did with a hydroulic unit. Thats just my personal opinion though.
Old 07-26-2005, 12:00 AM
Tom, just an update. Pedal box is done, rear diff is modded and mounted, slushbox is out, clutch master is ready to be mounted. I'm waiting on flywheel bolts from kerbeck subaru (thursday) so I can bolt up the 5spd. Then I have to modify the shifter, make a shifter plate, cut the brake (and possibly clutch master) pushrod to accomodate pedal location, modify drive shaft (should be able to do it myself with my uncles lathe and my welder), make a stud for the starter to rest on and then reassemble. I'd say I'm about 40% to completion.
Old 07-26-2005, 10:40 AM
TorG0d
My own personal observations of driveline extensions: unless you're a damn good welder, I wouldn't try. I'd rather spend $100 to have it professionally lengthened and balanced than $250 or so for a new driveline, however much for a new rear diff, etc.
Of course, I don't know you, so I may be sorely underestimating your skills. If I am, I apologize, I don't mean to be insulting.
Godspeed
