Old 06-29-2005, 03:41 PM
87f383's Avatar
87f383 87f383 is offline
SFI approved flexplate?
Is there a better stronger option than the stock subaru flexplate. Mine is rattling when I start the car now and I have shattered one before. Just curious if there is a better option in case mine is taking a dive on me again....
1995 Subaru SVX
-Accel Green Filter *
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Alluminum Drive Pulley *
-Stage 1 Shift Kit
-Small Car Clear Lenses and Corners
-1997 SVX Grill
-17" X 7" Enkei Shoguns
*Thanks Dayle! (SVX Motorsports)
1987 Pontiac Formula 350
-Enough (Once I put it back together again)
Old 07-02-2005, 01:42 AM
I have another stock one if u need it.. if you are not running more than stock power, the stock flexplate should be just fine. Even with the 165shot of nitrous that Mike is running in hos stage 2 kit, the flexplate held up.
Old 07-02-2005, 10:22 AM
87f383's Avatar
Im just running bolts ons... I think better check the bolts when I get back from PA (leaving in 5 hours). Maybe they only put in garden variety junk bolts and they are failing... If so... its grade 8 bolt time.
I'll check it when I get back... hopefully I wont have to take you up on your offer... but thank you in advance for offering.
Aaron
1995 Subaru SVX
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Stage 1 Shift Kit
-1997 SVX Grill
Old 07-02-2005, 08:01 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
You may have a torque convertor issue. TCs can distort and cause the flexplate to break. Lock-up convertors are more prone to this due to the lock-up clutch or the pressure applied to it going awry. Also the bushing that supports the transmission end of the convertor can be worn out allowing the convertor to run off center but is generally accompanied by leakage past the seal.
Old 07-03-2005, 09:42 AM
87f383's Avatar
Looks like I'll have two things to check out when I get back to dallas. Thank you very much for the further info.
Aaron
1995 Subaru SVX
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Stage 1 Shift Kit
-1997 SVX Grill
