Old 06-28-2005, 06:39 PM
dromano's Avatar
dromano dromano is offline
Originally Posted by Mr. Pockets
How did you arrive at those numbers?
One of the cooler mfg's listed this info in their installation instructions, I think it was Perma Cool. Could have been Hayden, can't recall.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 06-29-2005, 01:23 AM
Radar Radar is offline
Originally Posted by mbtoloczko
What did you use to cut the holes. Looks very clean.
They plotted the outline of the holes on a self adhesive foil to get even distances. Then started with drilling holes with the full diameter at the ends and cut the rest with a sharp rotating tool (I don't know the exact expression). This way you get a sharp edge of the paint with no cracks.
Old 06-29-2005, 08:11 AM
mbtoloczko's Avatar
sans SVX
Hayden has it in their catalog. According to Hayden, the ATF cooler will be 60% efficient if it mounted between the radiator and the fan. I'd like to see that in an SVX. :-)
Mychailo
Visit my locker
