Old 05-18-2005, 03:55 PM
drivemusicnow's Avatar
Poor College Racer
What is the lowest offset that has been used with 8 inch wheels?
I'm trying to get wheels that will work on both of my cars, and I"m trying to figure out what offset works with both.
The eclipse likes a 38 or so offset, the svx likes a 48.... whats the lowest the SVX can go before they start rubbing on the inside of the spring.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 05-18-2005, 04:04 PM
Aan 8" rim w/48mm offset will already stick out about 1/2" (or 13mm) more than stock.
See how much room you have to play with on your car as not all SVX's are the same. (A tire may rub on one SVX but not on another)
Old 05-18-2005, 04:39 PM
SVXelerator SVXelerator is offline
Frequent User
Mr. Greg,
I believe Mr. Chike and Mr. SVXRide both use the 3rd Gen RX-7 rims, which are 8" wide with a 50mm offset. I don't think either one of them has said their tires rub....
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 05-18-2005, 05:20 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
The 18x8's I'm selling are 42mm offset, and I've had no problems what-so-ever on my old 94, or my current 96. There's no difference in how far they stick out either...atleast no difference perceptible to the naked eye.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 05-18-2005, 07:51 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by SVXelerator
Mr. Greg,
Correct specs - 16x8" with a 50+mm offset. No rubbing with stock sized 225/50 tires. I'll be switching to 245/45 all season tires when my current summer-only Dunlop SP Sport 8000 tires wear out.
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-18-2005, 10:26 PM
mbtoloczko's Avatar
sans SVX
Its going to depend also on what width tires you use. If you go with 235s or wider, good chance you'll need at least a 45 mm offset.
Mychailo
Visit my locker
Old 05-19-2005, 07:14 AM
Poor College Racer
Does anyone on here have 8 inch wide wheels with 235/45 tires??
I don't think the STi rotas will work because of the 48mm offset. I guess I don't really know if a spacer is "safe" or not. I don't understand why it wouldn't be, however the general consensus i've heard is not to put 48mm offset and a 10mm spacer on the eclipse, even though this seems like it would be the best option.
Greg
Old 05-19-2005, 07:48 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Hey Greg...is there something wrong with the DSM wheels? If you are looking for straight performance on that beast, I would recommend keeping stock wheels and really good rubber.
That way you could get whatever wheels you want for the SVX. I don't think that you are going to find a wheel that works *well* with both cars. Especially if it is for performance reasons.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-19-2005, 08:15 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I'm running 245/45-16's on my RX-7 rims with no rubbing at all. Note: I am running -1.5 degrees of camber, front and back.
I think Tom's son's SVX is running 245/45-16s on stock rims without any problems.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-19-2005, 11:42 AM
Poor College Racer
Well, the brakes i'm looking to get for the eclipse are 13inch rotors, and that eliminates the stock wheels from working out. I was planning on roasting the rest of the dunlop SP5000s, and then getting the new wheels and tires along with the new brakes. I'm looking at the kuhmo MX's or falken azenis for a cheap grippy tire to go on these. don't think i want to step up to a "race" tire yet.
Greg
Old 05-19-2005, 01:43 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
Hey Greg,
Have you looked into getting some DSM 17" wheels? I know of a few sets for sale around here in Denver. Those should clear the 13" rotors. I think the 3G's have 17" wheels too..
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 05-23-2005, 02:54 AM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
I tossed a set of stock EVO rims on my SVX briefly... they're 17x8 +38 IIRC. The rears rubbed a little on the fender, but that was easily fixed by removing the rear liner trim and rolling the fender a tiny bit.
So, they "fit", but I wouldn't go quite that far on a regular basis. With the right tires, you can probably get away w/ a 17x8 +42 on the SVX... but I'm not sure if that will work on the DSM.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 05-23-2005, 09:39 AM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Lightbulb
I have the same wheels that Scott has here, and I also have had no troubles with rubbing at all on my '92 with the 42mm offset, however I would have to disagree with the part about not being able to see it sticking out further....the face of the tire and wheel are most definetly much more flush with the outside of the fender, thats one the reasons I like them (give the fender a full look). Chike, seeing as you jump on every post on earth...what would you say...you've seen them a few times
-Andrew
(ps, Im using 225/40 rubber)
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 05-23-2005, 09:04 PM
Chiketkd's Avatar
-Andrew
I'd have to agree Andrew. The rear wheels and tires (which are recessed on the stock offset wheels) are definitely flush with the body of the car.
-Chike
