Old 04-05-2005, 09:23 PM
Da'Cheat
Quick and easy tranny filter?
Hi
I just installed a rather large tranny cooler inside the drivers side fender well of the SVX. *Pictures and a how to will be up in a few days*
While doing this, I had a thought. Yea, yea, the first ones are always amazing.
The lines for the automatic trans are hard line, then 3/8" rubber tube to the radiator/trans cooler. Could one not simply install a large fuel filter that is barbed for a 3/8" line into the line to act as a tranny filter?
Fram makes a large filter with a clear case that should do the trick. They nab particles that are quite small and should be able to handle the heat and pressure of a transmission line.
Now, would the fluid be to thick for this application?
Would the filter have a high enough flow rating as not to hamper the fluid speed?
If there are no objections, Id like to give this a whirl. If it works, then It would be a quick, easy and cheap way to make our transmissions last longer.
Old 04-05-2005, 11:18 PM
thundering02's Avatar
Giong back to the beaters...
id like to say to thick but im not sure maybe some testing before installation would clear things up
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 04-06-2005, 05:50 AM
michael's Avatar
michael michael is offline
What Potholes ???
There is an OEM one on Ebay right now, same principle and it's easy to do.
Wanted: Steering Wheel
Old 04-06-2005, 09:47 AM
My understanding is that fuel filters will not work on transmission fluid because of the difference in partical size and filter media size.
Old 04-06-2005, 10:14 AM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
Perma cool
I like the Perma cool units. They have spin off filters and a spot for a temp sensor built in.
Steve
It's not a car..it's a boat!!
Old 04-06-2005, 03:35 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I wouldn't recommend a fuel filter. Why not just use an inline trans filter? They're readily available.
Old 04-07-2005, 12:13 AM
Da'Cheat
Why? It just seemed like a quick fix sorta thing. I was just rubbing my chin in contemplation on the matter.
Old 04-07-2005, 06:02 PM
A fine filter will restrict the flow too much, you only need a course screen filter, like the screen that is in the transmisson pan, just enought to remove the lumps. In this case 'the best filter, is not the best'
Old 04-09-2005, 07:16 PM
STORMINORMAN STORMINORMAN is offline
Lightbulb What's wrong with the SVX external tranny filter?
One would think it would be the most logical inline transmission filter one could ever imagine. Don't have to worry about particle size, etc. The recall kit even comes with a mount, clamps & hoses, too.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 05-02-2005, 08:29 PM
hpcsvx hpcsvx is offline
"how to" on the trans cooler install?
Just wondering if you've ever put up a "how to" on the install. I just picked up an SVX and am gonna do the "cooler in the fender" trick.
Also - got a good svx mechanic in Reno? I'm in Sac and Tahoe, so travel to Reno pretty often. Lastly - know any good welding shops that'll do a hitch for my SVX (gotta tow the dirt bike to all the killer riding in the Reno desert).
Old 05-03-2005, 08:20 AM
Sigh
Anyone know if they sell a 4" body lift for the SVX?
Steve
Old 05-03-2005, 09:35 AM
6" lift
Actually, it will take a 6" lift to fit the 36" tires on the svx!
In reality - I got tired of driving a boring pickup- SVX is fun and awd (I work in snow country in the winter). I just need to make it a little more versatile.
Old 05-03-2005, 04:17 PM
Take a look at the ground control kit. You should be able to lift the SVX that much depending on where you weld the new spring seat to the strut assembly. I'm sure the Koni's have more travel than the stock struts.
Plus when you want to you can lower it back to stock
Old 05-03-2005, 07:52 PM
I won't let them hijack this thread! Yes, there is a How-To in the Documents. (I think). I will check and if not, I will put one in.
Old 05-03-2005, 11:26 PM
thanks Ensteele
Thanks Ensteele - I look forward to the "how to". Hoping to get a trans cooler in the fender in the next week or two.
Just for the record - I DO want to get a trailer hitch to tow my dirtbike trailer. I DON'T want to lift my svx, put on 36" tires, install a winch on the bumper, or mount a pair of horns on the hood - although that would make for a pretty wild entry in a monster truck pull!
