Old 02-15-2005, 02:20 PM
n00b on demand's Avatar
power steering fluid ( i know its ATF)
Is the only way to replace it with a turkey baster? Or is there another way to drain it out. I wanna get the old ATF out of there and replace it with fresh ATF.
Old 02-15-2005, 02:26 PM
dcarrb dcarrb is offline
You could disconnect the return hose where it connects to the cooler and let it drain from there into a basin beneath the car.
dcb
Old 02-15-2005, 02:48 PM
That sounds like a good idea and probably would take less time. My mom has a huge turkey baster...maybe i'll give that a try too
Old 02-15-2005, 04:55 PM
The hose trick works much better.
Old 02-16-2005, 09:37 AM
Anyone got a pic of where this hose is? Is it on the passenger side of the rad or close to it or something?
Old 02-16-2005, 11:14 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
The hoses go down behind the pass side radiator, the cooler is sandwiched between the radiator and condessor. If you really need a pic, let me know as the race cars is currently just hanging out there. Might wanna remove the radiator to get in there and get the hoses off. Good time to flush that as well.
Old 02-16-2005, 12:00 PM
Replacing that return hose was the first order of business when I got my car, and it was no big deal, even for my clumsy fingers. Just unscrew the clamp at the bottom and let it drain.
Now that I think about it, if your return hose has never been replaced, now's the time. It's the same hose as used for the transmission cooler lines, sold at any parts shop by the foot. Cheap. Buy several feet of it and keep the excess in your trunk in case you ever lose an ATF cooler line while out and about.
dcb
Old 02-16-2005, 01:01 PM
dcb
Yea im gonna look into getting a new hose because the one i have now kinda leaks a little....not sure if its the o-ring or the hose. My guess would be the o-ring.
you have PM
Old 02-16-2005, 06:53 PM
zavikan zavikan is offline
trick
I needed to do this once, and didnt have a baster. I took a pump off a hand soap thingy, and pumped it out. wicked easy. and just throw out the thing when your done.
Old 02-16-2005, 09:03 PM
fortunatley my mom gave me a huge turkey baster lol.....one time will take out all the fluid
