Old 01-17-2005, 09:29 PM
92SVXMan's Avatar
92SVXMan 92SVXMan is offline
Slider Pulley?
I am a Newbie so please bear with me, I have a Chilton's book (which i think sucks) but it calls the Tension adjustor a "Slider Pulley"? I have checked the parts stores online and can not find this part listed, are there other names for this part. My Crankshaft Pulley came apart and i want to fix everything in one go, also have a oil leak so want to pull the oil pump too. But i need this part number to replace the Bearing on the slider bolt.
Thank for the help.
_______________
92svxman & Freida the co-pilot.
First 92 Claret(flat color,IMHO)
Two 92 Teal(much nicer color)
5 Speed pending, from 93 Legacy Turbo
4.11 Tranny/rear diff. May go for 3.90
Claret 145K
Underdrive Pulley from Newbies2005
New timing belt
new radiator
new water pump
new timing belt cover
New headlights and harness
Replaced exhaust (with stock)
Life on the road who could ask for more
Old 01-17-2005, 11:35 PM
Try looking here.
Good luck with it.
Old 01-18-2005, 10:52 AM
92SVXMan's Avatar
Originally posted by ensteele
Try looking here.
Good luck with it.
What i am trying to say is that i have been to Subaruparts.com and 1stSubaruparts.com and can not find the part, or the part# for the Bearing for the Slider Pulley. Getting to Subaruparts.com is no problem, everything else is.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-18-2005, 11:25 AM
dcarrb dcarrb is offline
If you're referring to (what I call) idler pulleys for belt tensioning, I doubt Subaru carries replacement bearings for these; they'd rather you buy the whole assembly. Pretty sure I've read here of someone disassembling and repacking (or replacing?) these, though. You might want to do a search. Good luck.
dcb
Old 01-18-2005, 01:08 PM
My dad just replaced the bearing in mine. He did it while I was waiting for the replacement pulley from Subaru. I'm not sure where he got the bearing from.
Old 01-19-2005, 08:17 PM
92SVXMan's Avatar
Pulley Assembly
I have been looking for the "Pulley Assembly-Idle Air Conditioner" Part# 73015PA000 which cost $42.37; S&H $7.95 so thats $50.32, but all i need is the Bearing which i found for$8.00 plus $1.16 taxes. What i did find out was that the Pulley was put on backwards, and that was why my A/C belt broke just before the crankshaft pulley came apart. I now have an Underdrive Pulley for the crank, and a new Timing belt to put on after i replace the O-ring behind the Oil Pump along with the oil pump seal. I just don't want to take the Timing belt off again any time soon. Thanks for all the help.
Drive fast, be safe and be happy.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-20-2005, 09:15 AM
AFBeefcake's Avatar
Subaru Swapper
Do you have a part number off the bearing you used, and where did you get it.
I've been tring to track this down for some time now.
2005 Legacy GT
My WRX's Cardomain Page
Old 01-20-2005, 09:49 AM
92SVXMan's Avatar
Thumbs up Pulley bearings
There is only one nut that holds the pulley in place, undue nut belt will go loose and remove the wheel and bring it to a shop that rebuilds starters/Alt. and there set you up for under $10. You can also bring it to NAPA and let them look it up, but in either case its going to be cheaper then getting it from Subaru. Good luck. let me know how it goes.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-20-2005, 01:53 PM
Subaru will only sell you the entire pulley p/n: 34413PA000 for $38.06 on subaruparts.
Reference Link
According to the PM I received:
It says 6202LU made in taiwan tpi
Old 01-20-2005, 01:58 PM
AFBeefcake's Avatar
Subaru Swapper
I think I can get those at work. I'll have to check.
Info I found on this bearing.
Its a standed size
6202 LU
Bore 15mm OD 35mm W 11mm
15,000 RPM max
Contact Sealed Type
2005 Legacy GT
Old 01-20-2005, 03:33 PM
92SVXMan's Avatar
Thumbs down 6202 Bearing
Reference Link
Sorry to tell you but the 6202lu bearing is for the Alt. and not the power steering. The P/S bearing is smaller.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-20-2005, 03:37 PM
92SVXMan's Avatar
Cool The Bearing
Its a standed size
6202 LU
15,000 RPM max
Contact Sealed Type
This is for the Alt. The P/S bearing is smaller. Good luck.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-20-2005, 03:41 PM
AFBeefcake's Avatar
Subaru Swapper
O well I'll have to take the pully off when I rebuld my power steering pump.
2005 Legacy GT
Old 01-20-2005, 04:13 PM
I thought you were referring to the tensioner pulley bearing?
Old 01-20-2005, 04:18 PM
AFBeefcake's Avatar
Subaru Swapper
yes, tensioner pulley bearing. I want to replace that at the same time as rebulting my power steering pump.
2005 Legacy GT
