Old 01-17-2005, 04:16 AM
The Molinator
Service INFO....PLEASE?
What is the factory recommended service interval for:
1) Change spark plugs
2) Change timing belt
THANKS!
Jim
Old 01-17-2005, 07:07 AM
tooth
Hey Jim - If you go to subaru.com and select owners/subaru care/maintenance schedules and then select your model and year, the factory maint schedule is available online. Hope that helps.
Todd
Old 01-17-2005, 10:28 AM
There is also one in the "How-To Documents"
The usual is 60,000 miles.
