Old 12-09-2004, 08:58 PM
lee lee is offline
Any metal roofer types out there
I'm just finishing up building a nice 10X14 wooden shed. It has a simple shed roof.
I'd like to put on a galvanized metal roof, but can't figure out what to do at the upper edge and sides to keep wind driven water from getting under the edge. The lower edge I just assume regular drip edge (but I still wonder about water getting driven in by rain. I was planning to put on 5V crimp panels.
I can't find anyplace on the web that deals clearly with the edge fastening for metal roofs. The local Home Depot sells a bunch of stuff (drip edge, a J-chanel, z-flashing, and a large L shaped piece) but whenever I go there nobody knows what I need to make this work.
tia
Old 12-10-2004, 12:56 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Is this of any help?
http://www.casupply.co.uk/acatalog/c...d_fixings.html
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 12-10-2004, 03:15 PM
lee lee is offline
thanks Andy, but not really. The roof panels look like this:
^^______________^______________^^
they are 24 inches wide when the outer Vs overlap from one panel to the next. The Vs are a bit less than an inch in height.
so I'm wondering what I do at the top of the shed roof when water could get in the upside down Vs, and what do I do at the sides (eaves/rakes) to keep the wind from lifting & ripping.
Old 12-10-2004, 06:41 PM
Old Fogey
lee,
My eldest son is the program manager for a medium sized roofing comoany here in Sac, and they install a lot of rubber membrane type roofing. You may want to look into that as an underlay for your galvanized cover. Just a suggestion. If you like I'll ask him for a manufacturer's name.
Glenn
Old 12-10-2004, 08:00 PM
lee lee is offline
Originally posted by RojoRocket
lee,
Glenn
Thanks Glenn, but I already put on some stuff called Rooftop Guard II. It's pretty tough for an underlayment - I know of a couple of cases where it was put on after Hurricane Francis and survived Hurricane Jeanne intact (final roof not on until post-Jeanne).
BTW, I just came back from Home Depot and they finally had someone on the floor who knew something...guess I've answered my own question - the solution is to install gable flashing on 3 sides, regular drip on the low edge, and use a closed cell foam under the Vs at the ends (they sell the foam pre-cut/shaped, but of course don't stock it - gotta special order).
