Old 09-22-2004, 12:15 AM
Mizery
Front Suspension replacement
Since I know nothing at all about this topic, you'll have to make it pretty laymans.
I managed to grab some PDF's of the suspension of my SVX off the techinfo.subaru.com website. I put one of them (mainly just a stats table) for viewing here. http://aenslaed.mizery.net/frontsus1.pdf
Now here's the thing. My front left strut is cracked (and its making some pretty unsettling clack clack sounds whenever i hit a bump). Knowing the kind of cost SVX oem parts are, I could/would problably find something better aftermarket for a similar price. Here is where you guys chip in
What is a good replacement for the stock SVX suspension that is similar in price (I'll have to call up subaru on this). I dont want to alter the ride height of the car as it is pretty low as is. Maybe make the car a bit stiffer but not by much.
Any help is appreciated.
edit: I do believe mine is the LS-L model.
edit2: While on the topic of replacement parts, is the Master Cylinder for the brakes known to have problems? My brakes are so spongy :/
Old 09-22-2004, 01:01 AM
Bobb Bobb is offline
Parts
Hi Mizery, For struts you don't have a lot of choice. Struts don't effect the ride height. Thats the springs job. OEM will probably be the best overall if you would like to keep everything pretty stock. You might check KYB and KONI, however KONI are inserts not the whole strut and they are on backorder right now. As for spongy brakes, I would have the brakes bled. Also bled them till clean brake fluid comes out of each wheel cylinder. Take care and happy SVXen, BOBB
Old 09-22-2004, 06:40 AM
mbtoloczko's Avatar
sans SVX
As Bobb said, you are stuck with the OEM struts (which really are pretty good). There is no aftermarket strut for the SVX (but Koni does make a high performance damper insert that goes into the OEM strut), and there are no struts from other Subarus that will bolt in place. I don't know of anyone who has looked at compatibility with other brand/models of cars.
Mychailo
Visit my locker
Old 09-22-2004, 08:34 AM
Mizery
I was thinking of doing the struts, shocks and springs all at once. The previous owner had beaten on the car quite badly and there are a ton of parts that need replacing.
Keeping with OEM struts, how about springs and shocks?
Old 09-22-2004, 09:53 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You can't go wrong with Mychailo's
("mbtoloczko") springs and Koni inserts. Classic Garage should have the Koni inserts in stock in October.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-22-2004, 02:32 PM
We hope!
Where is your strut cracked?
Do you have a picture?
