Old 09-08-2004, 06:21 PM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
Bearing Grease Mobil 1 Synthetic
Hey team,
Lot's of bearing talk recently... time for some more.
The facts: right rear bearing is shot at 11000 miles.
Got a replacement and picked up some Mobil 1 Synthetic Grease for the grease swap out.
It specs a temp. range of -40 to 350 F.
Is that good enough??
Anyone tried this stuff?
Thanks,
Biz
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
Old 09-09-2004, 09:14 AM
lanciat lanciat is offline
I used Mobil 1 synthetic grease when replacing both rear wheel bearings. 7K miles since and so far so good . . .
Joe Fillip
'95 L AWD ("The Wayback Machine")
Swarthmore, PA
Old 09-10-2004, 02:21 PM
mark10t
I've been using Mobil1 synthetic products almost exclusively in my
SVX and other vehicles for a number of years. Their ATF and engine oil are top notch and even noticed a difference years ago when I swapped out their gear lube in the manual transmission of my cars (have you ever experienced -30 deg. F with synthetic vs. conventional gear lube?)
I have no direct experience with their bearing grease it has to be the 'miracle worker' that their other lubricants are, too.
Just make sure you completely re-pack the grease in the bearing (don't leave any of the 'transit/storage' grease in the bearing
Good Luck.
-Mark
Old 09-10-2004, 06:29 PM
UT_SVX UT_SVX is offline
livin in AZ
I used Royal purple bearing grease and so far so good, I would absolutely reccomend a high quality grease over conventional. Darren
"Stand up Strong, Feel the Pain! Till the Angels Sing"
Social Distortion
1992 LS-L Pearl White :Optima Red Top, Motorsports Warehouse drop springs and swaybar bushings, Race Concepts slotted and dimpled rotors ,SS brake lines,semi-metalic brake pads, 4.11 5 speed, STi short shifter and tranny mount, Exedy sport clutch, Kartboy shifter bushings, intake silencer removed, ECU Tune Stage 1 v4
Old 09-10-2004, 11:22 PM
Green1995SVX
What's most important is that you make sure you remove all of the shipping grease from the bearing when it arrives from subaru.
