Old 07-12-2004, 12:27 PM
svxsubaru1's Avatar
Oil starvation?
The SVX is my second real car 17 years old, i did a couple of auto cross with my previous car and liked them alot. Latley since its summer i aculy have time to do some, and maybe do a track day. Ive done some mods to my car to make it fell better, i converted it to a 5spd put some mettal master pads on it and rear camber bolt, but have been kind of scared away with oil starvation storries that have killed some engine and since i really dont want or have the buget to replace a engine, i really dont want to kill my engine. So my quetion is will the SVX have oil starvation problems on a track or auto cross, i never heard of a problem with the SVX, but then there arent to many people who auito cross, or race them. Thanks
Old 07-12-2004, 01:51 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I haven't heard of any SVX engines being destroyed from oil starvation during an AutoX or racing session. So long as your dipstick shows your oil level being filled to the correct level (between L and F) you'll be fine!
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-12-2004, 06:35 PM
I would be more concerned that the transmission would go out!
Old 07-12-2004, 10:55 PM
Da'Cheat
Do not over fill the oil in a svx. These cars are well known by the dealers to have thier seals go out due to a half quart too mutch oil. Also, due to the high rpm's that the 3.3 commonly hits, keep the oils to a 10w30 or a 5w30 full syn. or semi synthetic blend. A heavy weight oil will not be pumped fast enough at high rpm's and lead to premature wear on the engine.
Old 07-13-2004, 12:02 AM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
With an oil capacity of nearly 7 quarts, its not a real issue. For what its worth, I also use ER (Energy Release) as a metal conditioner with my oil. I have done so since owning the car (over 7 years).
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 07-13-2004, 01:35 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Unless your oil light comes on when maneuvering, your engine is getting oil. I have a POS Honda that consistently gives me an oil pressure warning light if I dive hard into a right-hand corner. If the oil is a bit low, it'll give me a light if I dive hard into a left-hand corner. If the oil is extremely low, it gives me an oil light if I drive any way but straight ahead.
Before I rebuilt the engine on that hunk of rust, it burned so much oil that it was always low. I found that even when it was three quarts low, it had enough oil to prevent the oil light from coming on during more normal driving. If the light started coming on when I accelerated, then it was time to add more. At that point, three quarts was enough to get it to register on the dip stick. Adding a fourth quart was enough to get the level between the high and low marks. The engine would happily accept two extra quarts, but two and a half would cause an array of funny problems, including smoke from the exhaust and oil bubbles in the air filter housing and on the dip stick.
Granted, the SVX is a different beast, so my experience with the Honda is only a rough indication of how the SVX would react. Nevertheless, unless your oil light comes on, you should be okay. There are some rare situations where the oil warning light does not give warning, but this is quite uncommon. If you're concerned about it, getting an aftermarket oil pressure gauge is the best way to find assurance.
P.E.T.S. (People for the Ethical Treatment of Subarus) Disclaimer:
No SVXs were harmed in these experiments. None of these abusive experiments have been attempted on an SVX. Hondas have been used for situations that might place any real vehicles in danger.
UberLocker
Old 07-13-2004, 05:44 AM
red95svx
I'm not sure I agree. I haven't really heard anything about blown out seals caused by ONLY a half quart over filled. I read an article in a car mag a while back that said that most cars can handle more oil than the manufacturer recommends, as long as it isn't a lot more (like a quart or two).
High RPM's?? Are you kidding? My SVX barley breaks 4,000 RPM's during a typical drive to work. The car will do 90 MPH at 3,000 RPM's.... a low RPM for such speed. My Outback reaches higher RPM's than my SVX does........
