Old 05-24-2004, 01:51 AM
moshols vx moshols vx is offline
oops
oops posted too early! anyway, white svx IGNORED ME. Plates were even SVX 092 so u would think they would be a fan or happy to see another svx.... Oh well.
Mine is suffering from living ungaraged at beach. someone scraped the side rear bumber when parked the other day this revealed black surface underneath...... will leave it another month and head to panelbeater.
Moshol
Rubbing hands gleefully for Sunday meet
Old 05-24-2004, 02:10 AM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
Re: oops
Hang on - doesn't Arthur have those plates on his burgundy SVX?
I know that it wasn't SVX-093 either, because I saw that one about a month ago, and it was Charcoal Grey (by far the BEST colour for an SVX!)
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 05-24-2004, 04:33 AM
pylon500's Avatar
pylon500 pylon500 is offline
the Flying Member
Send a message via AIM to pylon500 Send a message via Yahoo to pylon500 Send a message via Skype™ to pylon500
SVX-092
Hey, that's my plate!
And yes, my car is Burgundy, maybe it was the car I spotted back in March;
http://www.subaru-svx.net/forum/show...012#post196012
His plate was
AAS-49Q?
Actually you won't see mine around for a while I suspect, as I've just seized my power-steering pump , but I'm willing to sit on the side line for a bit to do a better deal than the $1125.30 that Subaru Bankstown want!!!
Good thing I've still got my trusty ol' 4x4 'L', (do all SVX owners have to keep a spare car?)
Arthur.
'80 DL 4x4 Wagon-White (gone)
'91 DL 4x4 Wagon-White (gone)
'92 SVX LSi Burgundy/Black with wing. (gone)
'04 Liberty B Spec 3.0R wagon-Silver
'02 Outback 2.5 wagon-White For Sale
I Don't Drive Fast, I Just Fly Low!!
I've moved to Taree , check out my progress at Picasaweb.
That's a 'V' in SVX dammit!
Old 05-24-2004, 04:53 AM
JDW-SVX's Avatar
Arthur.
No - I am a good example of that!
Maybe I should think about getting a spare...............
.................BANG!!.......................
...............there goes my power steering pump!
Jason.
Old 05-24-2004, 07:54 PM
SVX-092
His plate was
AAS-49Q?
Arthur.
Authur, could you get the pump off one of the two wrecked cars. Should be cheaper. Why did it seize?
Old 05-25-2004, 05:51 AM
JDW-SVX's Avatar
Originally posted by oab_au
Why did it seize?
Good question - what happened?
Jason.
Old 05-25-2004, 06:24 AM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
There is a white QLD car with the rego SVX-092
Hmmmmm
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
Old 05-25-2004, 06:50 AM
pylon500's Avatar
the Flying Member
? Which two wrecked cars do you mean?
Countess's black car is no longer at Brooky Spare Parts, and no other left over bits there either.
So far the prices quoted to me are;
$1125.30 AUD- Bankstown Subaru,
$ 525.00 USD- from Paddlesnz in Japan,
$ 395.00 USD- SUBI-PARTS.COM,
$ 125.00 AUD for a 2.2 Liberty pump from my local wrecker
This pump has a different fitting on the outlet, with a differnt kind of pressure relief valve?
Will have to check on the operating pressures of the Liberty pump to see if I can adapt it to the system.
I had a problem getting the pump off my car as I could not undo the nut on the pipe leading from the pump, actually had to 'rotate' the pump off the pressure switch adaptor, and catch all the regulator bits
The nut on the pipe has little marks that I associate with meaning a reverse thread, but couldn't move it either way!
Questions; Is this a reverse thread?, and, is the pressure switch just to sense low pressure, or an intergral part of the operation of the pump?
Why did it seize?
Ever since I got the car, the power steer pump was a bit noisy, mainly when parking, I thought it might be the front bearing although there didn't feel to be any free play.
I assumed it was normal until last week when the steering started to get heavy.
When I checked the oil level, I noticed the oil was dark (and a bit irridescent!)
I spent all morning draining the system and flushing with fresh fluid, then refilling and hand cycling the steering (with the front wheels off the ground) to remove all the air, only to still have heavy steering under about 1500 rpm.
I decided I needed another pump, so went off to my local Subi wrecker (All Parts Are Us) and found a Liberty pump that looked identical.
While actually driving down the road away from the wreckers there was a screaching sound and the engine stopped!!
When I looked under the bonnet, the p/s pump was locked solid!
With insufficient tooling, and no oil, I removed the pump belt (which meant no alternator) and drove home with the dash ablase with lights!!
(Actually didn't drive too bad, only a little heavier to park)
When I got the pump out and apart, it looked like about three of the vanes had shattered and basically gutted the pump housing (no reco' for this pump!)
One interesting feature was a small round hole in the side cover of the pump which looks like there may have been a small piece of vane 'spinning' in the oil flow for a while to machine out said hole. (wish I had a 'MACRO' digital camera!)
I'm ready for advice, (and pumps!)
Arthur.
Old 05-25-2004, 04:24 PM
JDW-SVX's Avatar
From what I understand, that switch is only there to sense low pressure, which would occur when a high load is placed on the pump at low revs (i.e. turning the wheel hard while stationary, and with the engine at idle)
This signals the ECU to activate the Idle Air Bypass Valve, so that the idle speed can be increased.
Therefore, I believe that the switch does not affect the operation of the pump itself....................
...............but I could be completely wrong!!
Jason.
Old 05-26-2004, 03:00 AM
pylon500's Avatar
the Flying Member
Makes sense to me, Although I'm beginning to think it was never working then as my idle would never pick up while trying to park.
(Thinks,) Have we highjacked this thread?
Arthur.
Old 05-26-2004, 03:28 AM
JDW-SVX's Avatar
Arthur.
Absolutely - but it is all in a good cause............
...........we must get your SVX back on the road ASAP!!
Jason.
