Old 04-30-2004, 04:23 PM
Thumbs up I'd like everyone to look at this -> *pic update*
http://www.subaru-svx.net/photos/fil...u_S./17333.avi
Should I keep driving it?
[edit]
New pulley on the way.
Old 04-30-2004, 04:28 PM
I don't have much choice in the matter being that UPS lost my freaking Stealth ECU.
BBL.
Old 04-30-2004, 04:32 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
NO!
Get a new pulley at once!!! Sounds like the pulley is hitting the motor. The bolt is running true, the pulley is not. Where did you get that pulley?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 04-30-2004, 04:36 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. Stop driving the car and get a new pulley ASAP!!!
2006 Steel Gray WRX TR (sold)
Old 04-30-2004, 04:53 PM
Mr. Pockets's Avatar
Moderator
I'd go get a new pulley immediately. The only thing it's going to rub against is the timing belt cover, which sometimes happens with the OEM pulley anyway. But that wobbing isn't good at all. Your crank and bearings are probably fine, but you're definitely placing more strain on them with that wobbly pulley.
By the way, this belongs in the tech q&a forum.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-30-2004, 06:08 PM
mbtoloczko's Avatar
sans SVX
Re: I'd like everyone to look at this ->
How did that happen?
Mychailo
Visit my locker
Old 04-30-2004, 07:22 PM
michael's Avatar
michael michael is offline
What Potholes ???
Mine does that sometimes, did you try tightening it, the nut could come loose. It needs to be done with a touque wrench or impact gun I'm not sure about what the setting is, anybody?
Wanted: Steering Wheel
Old 04-30-2004, 07:44 PM
It has been doing the wobble thing since the water pump seized but has only been clicking for about 3 weeks. I don't see how getting a new pulley will help. Do you think the pulley is warped?
I don't have the means to tighten it.
At one point in time after replacing the water pump (june of last year) it actually did an in-out motion (stock pulley).
What can I expect to happen in time without fixing the problem? Be specific.
Old 04-30-2004, 08:12 PM
michael's Avatar
What Potholes ???
A socket wrench should do for now.
Old 04-30-2004, 09:16 PM
I don't have one that will fit. Are we sure this will cure the problem temporarily?
Old 04-30-2004, 09:51 PM
mbtoloczko's Avatar
sans SVX
You should at least remove the pulley to determine what exactly is bent or deformed. My guess is that the pulley is wallowed out.
Mychailo
Visit my locker
Old 04-30-2004, 10:01 PM
The last time we removed that thing I needed a huge hammer and wrench, a cheater bar, and 3 guys wailing on it. I don't have these resources anymore.
I have nothing.
'Cept a broken car.
Old 04-30-2004, 10:10 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
easy stuff
Getting that bolt off is easy....all you need to do (and this was told to me by eddycat, a subaru mastertech...and it worked great) is a breakerbar and socket that fits that bolt. Attach the breakerbar and socket on the bolt. Brace the bar against the ground. Have someone put their foot on it to hold it in place and then put the key in the ignition and crank it for a split second. Breaks the bolt free just fine. Torquing it back down after you get it changed is another matter. I used a strap wrench along with help from Dr. Kuo and we got it tightened back down again.
You could probably have that pulley changed in an hour with this method and it only takes two people with little effort to do.
Hope that helps some.
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 04-30-2004, 10:14 PM
I've heard of this method and I may do that. The problem is finding something strong to brace the bar against.
Old 04-30-2004, 11:04 PM
halistan's Avatar
Grand Poo-Bah
What do you mean? Are you talking about the end of the breakerbar? I used the ground with Kuo's foot on it to hold it there. Really it works great, try it.
