Old 12-19-2003, 01:50 PM
SVXphile's Avatar
SVXphile SVXphile is offline
Ain't it the truth?
Send a message via Yahoo to SVXphile
Thumbs up
Originally posted by huck369
The stock pulley is actually 2 parts the inner part that the bolt goes through, and the outer part the belt go on, they are put together with rubber and the rubber can deteriorate and cause the inner and outer parts to become loose from each other, allowing the outer section to come off.
OK....now what I'm seeing makes some sense.
Thanks Huck!
Don
PS I clicked on the Motorsports site and looked at the underdrive pulley. Does it also have this "two part" construction? Are there any disadvantages to using it vs. the original design?
Cats: Clio, Inky, Sheba, Sparky, Rocky, Cali, Scooter
3 cars: 02 SVT Focus, 2012 Versa...2015 Fiat 500
currently SVX-less
1 wife ("She, who must be obeyed..")
"One advantage of being disorderly is that one is constantly making exciting discoveries"
Old 12-20-2003, 06:35 AM
Nope, the underdrive pulley is one peice, so you don't have to worry about it coming apart.
The only real downside to them is that they lower the charging capacity of you alternator, due to it turning slower, but only really effects it at idle.
Old 01-21-2004, 10:34 AM
Special tool?
Don says his crankshaft pulley/harmonic balancer came in today. He asked me what the torque values were, so I got him the info from the service manual, which was 108-123 ft.lbs.
As part of the timing belt replacement, it showed a special hand tool for holding the pulley stationary so that you could loosen the pulley bolt and tighten it to the correct torque. It is called a "crankshaft pulley wrench". It looks like a long breaker bar with a disc on the end with a hole in the center to allow the pulley bolt to protrude through and either 2 or 4 pins which must match up to holes in the pulley to keep it stationary. You slip the tool over the bolt and into the pins and hold it with one hand while you tighten or loosen the bolt with a wrench in the other hand.
Is this tool exclusive to the SVX or something that any shop who does timing belt replacements would have? Is there another "trick" or tip to stabilize this pulley so that he is not trying to turn the crankshaft while loosening or tightening it? (With the free play in a moving pulley, accurate torque specs could not be obtained.)
How would he get a tool like this, if a Suby shop did not do the work?
Old 01-21-2004, 11:29 AM
Re: Speciual tool?
As part of the timing belt replacement, it showed a special hand tool for holding the pulley stationary so that you could loosen the pulley bolt and tighten it to the correct torque. It is some sort of "crankshaft pulley wrench". It looks like a long breaker bar with a disc on the end with a hole in the center to allow the pulley bolt to protrude through and either 2 or 4 pins which must match up to holes in the pulley to keep it stationary. You slip the tool over the bolt and into the pins and hold it with one hand while you tighten or loosen the bolt with a wrench in the other hand.
i used a breaker bar on the pulley bolt, resting on the alternator(and duct-taped to it so no slippage) and a brief turn of the key to loosen the bolt. (thanks Subafreak!) i tried a strap-wrench and breaker bar, but no dice, so i used the sketchier method.
to tighten, the strap wrench was able to hold the pulley enough for the torque wrench to click at 115 ft-lbs.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 01-22-2004, 01:46 PM
I checked around and it seems that Subaru has specialty tool manufacturers make their tools. The cost of this particular one is $182.83, plus shipping.
Anyway, here is a drawing of the tool being used, as well as a drawing of the tool itself. It seems like something that could be easily fabricated to do what it needs to do. This came out of the 92 SVX Shop Manual. Any other ideas?
Old 01-22-2004, 02:05 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Didn't John McKenna (svxcommuter) fabricate some kind of tool (Besides the famed Frankenbleeder). If it wasn't for this purpose, he could probably fabricate one.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-22-2004, 02:33 PM
Mr. Pockets's Avatar
Moderator
I bet any one of us cold go to Menard's and pick up ten dollars worth of parts to make something similar. Two hundred bucks, my ass...
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-22-2004, 03:02 PM
Aredubjay's Avatar
My, we're being testy these days.
Randy Johnson
Old 01-22-2004, 06:12 PM
Bobb Bobb is offline
Re: Ruminating
Originally posted by Ron Mummert
It's about right if you can convince Jean that it's the perfect little stocking stuffer for the SVXaholic.
Ron (ruminating).
Hi Ron, Lets see, ruminating, does that mean you have four stomachs and give milk? Of course the best part is regurgitation and chewing your cud. Oh wine steward, what would you suggest to go with my cud. Thunderbird, I have a nice '92 that would go very nicely with cud. Take care, BOBB
Old 01-24-2004, 01:34 AM
SVXphile's Avatar
Ain't it the truth?
Thumbs up
Thanks for all the help gang....especially John ( I got your messages).
In the immortal words of the Midas Muffler ad....
"I'll MAKE it fit!"
(Just as soon as we get a thaw around here!!!)
Don
How many West Virginians does it take to change a crankshaft pulley?
Depends on how much beer you bought for the occasion...
currently SVX-less
Old 01-24-2004, 08:18 AM
breaker bar - $10-15
strap wrench - $10-15
duct tape - $2
turning the key and letting the EG33 break that bolt loose for you........priceless!
Old 01-24-2004, 12:19 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
Re: Special tool?
The best Pulley holder on the market is a filter wrench that wraps a belt around the oil filter and tightens against it, using leverage you are able to untighten even the most difficult oil filters. This same tool works very well for holding the pulley stationary while undoing the bolt, but the belt on the tool must be long enough to go around the pulley, and support the handle with a pipe against the ground or other stationary object. I'f your not familiar with the tool, let me know, but most auto parts places and even tools places have them, they can even be known as large diameter Pipe wrench, that does not scar the surface of the item.
Duh, there it is, a strap wrench, sorry, didn't see all the posts above
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 01-24-2004, 12:22 PM
CDG's Avatar
CDG CDG is offline
duct tape - $2
Keep in mind, letting the EG33 break the bolt free will truly cause it too break, cause this trick helps you TIGHTEN the bolt
I'm not going to tell you why I know this
Chris G
Old 01-24-2004, 12:27 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
Here's a pic of when that happens:
split pulley
Old 01-24-2004, 12:47 PM
use this technique for loosening the bolt ONLY.
a strap wrench was able to hold it enough to apply 115 ft-lbs when TIGHTENING, but it couldn't hold the pulley enough to LOOSEN the nut.
if you try to tighten the bolt by using the engine, well.....you're a knucklehead.
