Old 12-09-2003, 07:02 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Full time 4WD?
IS the SVX a full time 4WD (I have a 1992 LSL)
I had trouble pulling out of the snow, in some occasions I had to have my uncle push so I could get out of the snow in a level parking lot. It wasnt alot of snow either. Could something be wrong with my 4WD???
Also as I was trying to pull out of the snow I noticed that only the front wheels would spin. Are all four wheeld supposed to spin???
Thanks guys
Old 12-09-2003, 07:29 PM
wawazat??'s Avatar
Yeah, I'm still around
Unhappy you've got a problem
you should get the car checked out as all four wheels should spin when slip is detected. Sorry
Down to none
Old 12-10-2003, 07:11 AM
CigarJohnny's Avatar
Check the fuse box and make sure the FWD fuse is not in.
Old 12-10-2003, 07:34 AM
awd
If it's not the fuse, it's usually the " single wire solenoid " at the tailshaft of the transmission, book time is around 6 hours, the gasket and seal are cheep, the solenoid is around $125.00. The clutch plates are around $300.00, but only replace them if they are worn.
Old 12-10-2003, 09:06 AM
Mr. Pockets's Avatar
Moderator
Yeah, there's something wrong with your car. Does the 'power' light blink sixteen times when you start the car? If not, then the transfer clutch is probably just totally worn out.
Sorry.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-10-2003, 04:03 PM
Thanks for all your help guys
where's the best place to buy those parts if I need to replaced them?
Does any one know a good mechanic within the Norwalk,CT 06854 area?
Old 12-10-2003, 06:58 PM
svx_commuter's Avatar
I do not know a mechanic in Norwalk. I replaced the transfer valve solenoid assy myself. First I checked the transfer pressure and there was none. That is a sure sign the solenoid assy is bad. If the transfer pressure is good then the transfer clutch plates are worn. To fix this the exhaust has to come down and then the drive shaft. After that the back of the tranny has to come off. I hope it works out for you.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 12-11-2003, 03:01 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
I'm up in northwest CT...if you're up to the trip there's my mechanic, Hank Schieb, Schieb's garage...(860) 379-4363 and Center Subaru in Torrington, CT does a good job.
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 12-11-2003, 03:51 PM
Green1995SVX
I think taking an SVX to anywhere but a Subaru Dealership for service is a big big mistake... That's just me though.
Mike
Old 12-11-2003, 06:59 PM
Moderator
Mike
I think it depends on the problem you're having. When it comes to Garcia's faulty transfer clutch, I thing you're right on. Nobody has had the sort of experience with the car tat some dealerships have had.
But I think that there are an overwhelming number of repairs that can be performed by a competent and (above all) careful mechanic.
2005 Outback
END OF LINE
Old 12-11-2003, 07:25 PM
Subafreak's Avatar
Superbeast
Here's a good question. What gos bad to make the center diff bind? Anyone? Anyone?
Old 12-11-2003, 08:21 PM
center diff
in a manual or an automatic?
Old 12-11-2003, 08:49 PM
center diff
If its an automatic, center diff bind can be caused by the front/rear clutch drum wearing and not allowing the f/r clutch discs and shims to move freely.Or if the single wire solenoid goes bad, and wont bleed off pressure and the f/r clutch plates have full pressure to keep them from slipping, hence 4wd and not awd.
If its a 5 speed manual and its locked up,either the f/r tires are different sizes, or the silicone filled center diff locked up, perhaps the first one ever to do so.
Old 12-12-2003, 01:04 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Mike
That depends on the qualitly of your Subaru dealer. I wouldn't let mine service a lawnmower
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 12-12-2003, 06:59 PM
Subafreak's Avatar
Superbeast
Re: center diff
Would drum wear look like 4 grooves worn into the inner drum? If so would fileing the grooves out be a good or bad fix?
