Old 11-27-2003, 11:42 PM
6evil9
O2 sensor
hi again
any ideas how to check the O2 sensor? and can they get dirty or something? and mite need some cleaning?
i was getting check engine code some time ago but its gone now
still terrible iddle (progressive) and bad as acceleration under 3000rpms
grrrr
Thx
Old 11-28-2003, 10:45 AM
lee lee is offline
Re: O2 sensor
Originally posted by 6evil9
hi again
I believe it requires an Oscope or similar test equipment. Long term observation of an air/fuel gauge can show a degrading sensor (speed of response on the needle). Basically, once warm, most if not all, read out between 0 and 1 volt. There's nothing to clean, its a pull and replace job. Search for how if you decide to DIY.
Old 11-28-2003, 04:10 PM
6evil9
are the readings from left and right O2 sensors are nearly the same?
if engine works ok then they are supposed to be the same.. right?
Old 11-28-2003, 04:13 PM
lee lee is offline
if the two engine banks are perfectly matched, then yes - to the precision of the sensor itself. But if one cylinder is misfiring then no.
Old 11-28-2003, 07:15 PM
6evil9
hmmm if i get too desperate ill connect the output from left O2 to the right O2
to c how the car would work.....
coz there is something really wrong with petrol system!
