Old 11-23-2003, 04:19 PM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
Question Do it yourself... or not??? Axle
How hard is changing the driver's side front axle? Is it something i should let me boyfriend do himself or should i take it to the shop to get done. He has all the tools at home and has done my brakes and the little things my car has needed in the past.
Jen
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 11-23-2003, 05:07 PM
lee lee is offline
changing the axle isn't terribly difficult. You either have to use Beav's trick of removing the three bolts connecting the lower A-arm or else will have to go out for a front end alignment when done. Plus I think it's a 32mm socket needed for the axle nut (not a common size - maybe 1-1/4" will work).
either way I think it would take me about an hour now that I've done it once, I think it took me about two hours on jack stands in the garage.
Do a search and print out directions, see if he can do it. Here's a greatly simplified version of what to do:
remove wheel,
remove axle nut,
remove 3 bolts on A-arm,
remove pin on transmission end of axle,
remove axle,
reverse,
live happily ever after.
Old 11-23-2003, 07:49 PM
wawazat??'s Avatar
Yeah, I'm still around
Easy job for you and Larry, Jen
Follow the write-ups here and you'll have it done in no time.
Todd
Down to none
Old 11-24-2003, 08:07 AM
CigarJohnny's Avatar
I'll be doing the same axle on mine very soon, Jen. Have it on order and pick up the reman axle tomorrow. Now I just need to find someone to assist with the heavy work who has off the same days I do. I'll let you know how it goes for me if I do mine before you do yours.
Old 11-24-2003, 01:15 PM
J. Bond
Thanks I think we'll do it ourselves but, i did a search and couldn't find the how to write up can someone send me the link?
Thanks
Jen
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 11-24-2003, 01:37 PM
Here you go!
http://www.subaru-svx.net/photos/files/How-To/10544.jpe
Always check the HowTo section first. There are better threads I found before when searching that give a little more detail than the generic ones in the link above.
Here is another one I was thinking of:
http://www.subaru-svx.net/forum/show...le+replacement
Just do a quick search in the tech forum on "axle replacement" Tons of good info.
Old 11-24-2003, 08:11 PM
J. Bond
Thanks again!!
Jen
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 11-25-2003, 05:59 AM
svx_commuter's Avatar
I think the front axles are fun to change.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 11-27-2003, 08:44 PM
You can use the 3 bolt Beav method but I've always used the one bolt method like the jpg in the how-to states.
