#46
Ah Ha!! I figured it out. The other plug IS for the cruise control. It's always open unless you're in 5th gear. I'll be wiring that into the same circuit that the clutch and brake use to disconnect the cruise.
Cruise is disengaged if: - press the brake - press the clutch - pull shifter out of 5th (plus the normal ways) I hooked up the battery today!! Reverse lights work, ignition works, clutch ignition (neutral) switch works, starter works! I may even get a chance to start the engine tomorrow!!!
#47
Kick ass
BTW: I first wired my B.U. lights to the neutral switch. No good
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
#48
The test I'm most worried about is the cruise control. I have a lot of soldered wires in that circuit! (If only I didn't have to work tomorrow) p.s. - happy new year!
#49
David,
Glad you're about back on the road, I bet you're really looking forward to taking her for a spin
#50
I did start the engine on the 1st for a few seconds. Had to shut it off though since I'm working in my parents' basement.
I'm having starter troubles as I see some other swappers are having. I turn the key and instead of turning over the engine the starter just clicks. People say that not enough voltage is getting to the starter so I'll have to check that out the next chance I get.
#51
I'm new here, and doing a 5 speed swap as well. I was hoping that you guys could answer a few questions for ,me too.
I'm using a '95 Impreza drivetrain. Will the 3.90 ring and pinion out of the impreza physically fit into the SVX diff? How did you guys wire up back up lights? Thanks a lot |
#52
As for will they fit...they will if it had the same style housing...but if it has the smaller housing it won't. Good news is the older Subarus (GL's and XT's) use the 3.90's in the correct size housing, so you can find one of those pretty easy (I have one myself, but it's a spare for my XT6) I'm running a 95 Impreza tranny in mine too...but it had 4.11's.... Best of luck in your swap,
#53
Earthworm, hope to see the 5 speed at Reading!!! We will be the only ones there with 5 speeds and Stebros!!!! Hehehe That is unless Mike (green1995SVX) decides to do a 5 speed swap instead of replacing his Auto...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
#54
#55
My SVX is currently undergoing the swap... I never planned on replacing the Auto. Also, my tranmission is from an Impreza and uses 3.90 diff's. Mike |
#56
Well then me and Huck will represent the 5 speeds with Magnaflows then
#57
I should be at reading as long as my engine goes in on schedule.
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#58
So that would be 5, 5-speeds there if we all make it?
It'd be a new record for sure
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" Last edited by huck369; 01-29-2004 at 11:20 AM. |
#59
Unfortunately the Impreza housing I have is the smaller one. So if I get the ring and pinion out of an old XT6 they should fit into the svx diff? I was thinking about just having rear axles made and mounting the impreza housing into my SVX. Does anyone know anybody who could build them?
#60
You'd lose your LSD rear diff, by using the Impreza Housing, plus the smaller housing isn't as strong, and you'll be putting 100HP more through it than the Impreza was....I'd recomend finding a good large housing 3.90 diff, and swap the ring and pinion into your LSD housing.
