Old 06-16-2003, 04:51 AM
LarryIII LarryIII is offline
Misc. Ramblings
Saturday morning I was at MFSD (my favorite Suby dealer) getting my front rotors turned. Most of you know that I warpped them trying to keep a tow truck from becoming a permanent hood ornament. They have an interesting new machine that does this. It's all computerized. First, it spins the disc. Then, it reads the irregularities in the disc starting from the outer dia. and working it's way toward the inside. When it reaches the inside, it beeps, the fingers holding the cutting tool close the right amount and it starts cutting and traveses toward the outter dia. again. Once it's done it beeps again and automatically shuts off. Unfortunately, the minimum thickness of metal that this machine can remove is six thousanths of an inch. Their old machine could do a min. of two thousanths.
Interestingly, the passenger side rotor was warpped slightly more than the one on the driver's side. I would have thought it would have been the other way around since my weight is always on the driver's side.
The brakes seemed pretty good after that but I have not given them a real test yet.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 06-16-2003, 10:08 AM
mbtoloczko's Avatar
sans SVX
Does it check the balance of the rotor?
Mychailo
Visit my locker
Old 06-16-2003, 11:24 AM
JLittell
What's the cost for each rotor??
Old 06-16-2003, 11:31 AM
Just Rambling ???
Larry - this is "impotant" stuff, you're not just Rambling.
Old 06-16-2003, 03:47 PM
First: Earl, When you feel "Impotant", You better act "Impotant."
Second: Little_J, Cost = $111 plus 6% PA sales tax.
Third: MBT, Yes when it first starts it spins the rotor, and checks its balance. Then it starts moving in and measures the waviness of the rotor then starts cutting toward the outside of the rotor.
Old 06-16-2003, 06:25 PM
Subafreak's Avatar
Superbeast
Wowie! My machine does the same thing for $14 a rotor.
Old 06-16-2003, 06:38 PM
Is that what you charge customer's?
Old 06-16-2003, 06:42 PM
Subafreak's Avatar
Superbeast
Only if you bring them in off the car.
It cost me nothing thoe.
Old 06-17-2003, 04:34 AM
I drove the 92 SVX into work today. The brakes work fine.
93 mph to 7 mph.... stopped straight and true. God, I love driving the Blue Route (I-476) at the crack of dawn. It was great this morn. The air was crytal clear. The temp. was in the low 50s. A rosy glow was streaking across the sky from the rising sun, and best of all, there was NO TRAFFIC.
It's really exhilerating to drive a terrific car on an empty super highway. I was singing along to the Pure Tenors CD with Guiseppe DeStefano blasting from speakers. What a great way to recharge one's internal battery.
I just know that I'm going to absolutely insufferable at work today.
