Old 12-06-2002, 07:21 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
u know u have to much hp whene
You Know You Have Too Much Horsepower When..
1. The emissions test guy starts laughing as soon as you pull onto the rollers.
2. You can't drive your car in the rain.
3. Your 'significant other' is afraid to drive your car.
4. You are afraid to drive your car.
5. You spend more on tires than on food.
6. You spend more on car insurance than on house payments.
7. You look in a state police car and see a picture of your car taped to the dash.
8. You throw your underwear in the garbage rather than the hamper.
9. You have to go to the track to buy gas.
10. Your mechanic names the new wing of his shop after you.
11. You measure the fuel you use in "gallons per mile".
12. Your engine idles at 2800 rpm.
13. You're tempted to wear your fire suit just to drive to the office.
14. Red signal lights shift to green as you're approaching then shift back to red as you're receding.
15. You arrive somewhere before you left.
16. You get pulled over for doing 155 in a 35 but the cops will let you go if "they can look under the hood."
17. You remove the $2000 stereo system to save 6 lb. of weight.
18. You are not allowed to run in the Silver State Challenge.
19. You get an anonymous phone call asking if you are interested in being in the Cannonball Run.
20. Your face looks like you are riding a NASA centrifuge when you drive the car.
22. You need parachute braking.
23. Your 'significant other' won't even ride in the car.
24 There is no possible way to "sneak out" of your neighborhood at 6 am.
25. Your pets scramble for their hiding spots as soon as the garage door is opened. (Pets, and all the neighbors...)
26. Family photos throughout the house are replaced with life-sized posters of your car.
27. Fuel is delivered to your home in 55 gallon drums
28. You carry earplugs in your car.(doesn't everybody???)
29. The only spot on the car which receives any regular cleaning is the windshield. (what else is there to clean???)
30. You find out that side mirrors don't hold up at speeds exceeding 145 mph.
31. Young children cling to their mommies in fear when you round the corner.
32. Birds fall out of their nests from the rumble of your 5" dual exhaust.
33. All the major Tire makers are sending you free slicks in hopes of endorsment deal.
34. The UPS guy took to taking Steroids so he could keep up with your shipments.
35. The Fed Ex guy had a nervous breakdown.
36. All the wildlife within a 800ft radius around your house got the HELL OUT.
37. The nearest Geological Seismic Surveying Station Operator knows your address by heart.
38. A booming voice greets potential passengers with, "That's right....you paid for the whole seat but you'll only need the EDGE.
39. The earth slows in rotation when you hook up on your new slicks and head east.
40. You have to screw your slicks to the wheels.
41. Your exhaust pipes are larger in diameter than your driveline.
42. Your fuel pump flows enough to water a golf course.
43. Your compression's high enough you could run diesel fuel.
44. The sparks from your wheelie bars start grass fires on the side of the road
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 12-06-2002, 07:22 AM
And a handy tool guide
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your drink across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouc...."
HYDRAULIC FLOOR JACK: Used for lowering a car to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to hollow out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short
Old 12-06-2002, 07:44 AM
Green1995SVX
Wow... 4 misspellings in the title... that has GOT to me a new record. Funny though.
Mike
Old 12-06-2002, 09:01 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
LMAO
I've done almost all those things (never actually owned a hydraulic jack).
Thanks, Solar.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 12-06-2002, 09:17 AM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
Originally posted by Dick Young
LMAO
Thanks, Solar.
I have, and trust me on this.... he's right
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 12-06-2002, 02:19 PM
$VX
You know you need to go back to 2nd grade when:
You can't spell.
- Ca$h
Old 12-06-2002, 03:18 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Mike
Followed up by a misspelled reply.
Old 12-06-2002, 03:35 PM
Green1995SVX
OHHH CRAP! STUPID STUPID STUPID!! *banging head on desk*
hehe
Mike
