Old 04-25-2018, 05:22 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
SVX Strut Top Mounts
Are the SVX strut top mount stud patterns identical to any other Subaru’s? Want to replace the ridiculously harsh K-Mac pillow-ball camber adjustable top mounts on the ‘94 emerald with the Whiteline camber-adjustable polymer top mounts. Not listed for the SVX, but listed for lots of older WRX’s, Impreza’s, Legacy’s, etc. Realize compatibility of front and rears may be different. Think the rears on the Emerald may still be OEM.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 04-25-2018, 07:21 AM
SVX_MY_BABY's Avatar
Re: SVX Strut Top Mounts
There is a thread here somewhere on modifying the WRX front to fit if I remember correctly.
I believe both front & rear are unique to the SVX.
Peter
Old 04-25-2018, 08:24 AM
In which case, Young Tom may well have drilled the strut towers to accept an alternate stud spacing, when he added the K-Macs, so I should reach out to him to find out what configuration he bought.
Old 04-26-2018, 12:48 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
I used the 05 sti coilovers. The top mounts fit fine but 1 stud must be repositioned.
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Old 04-26-2018, 01:15 PM
J-Man. I note from your signature that you have z-32 calipers with 13” rotors and 17” wheels. Did you have any fitment problems? I’m currently planning to do the 04 WRX 4-pot caliper/ Tribeca 12.4” rotor mod that is being touted over at SVX Nation on Facebook. Claimed to be a true bolt-on after adding the spacers to the calipers? I also have 17x8 Rota wheels. Any thoughts?
Old 04-27-2018, 01:54 PM
Jvan Jvan is offline
Not to highjack this thread but I am interested in the $ pot WRX swap as well and hope he answers soon.
