Old 04-26-2011, 05:16 PM
The Molinator
Re: Battery failure - intermittent, severe
Originally Posted by Cam View Post
That would not explain the stalling while car is running. The starter has nothing to do with the car once it has started. Did you check for a slipping crank pulley? After re-reading your OP I think huck hit the nail on the head.
Correct! They R evidently or at least probably separate issues. The "stall" was only once.. followed by the inability to start! The start "pause" issue was wat I was talking about now.. .
Yes, I checked my pulley.. It is aluminum, so I guess it's one piece. R U referring to slip that wud result in slow or inadequate alternator rotation.. ??
My car starts 99.99% of the time.. so I don't know what these strange occurrences were.. ?? I still think there was some bizarre intermittent short.. ??
Thanks, Jim
P.S. My 18 yo son was telling me how there may really be zombies, so .. . maybe the zombies are involved..
Jim
