Subaru SVX Fuse Box
I have a 92 Subaru SVX, the terminals on the lower part of the interior fusebox are corroded so I cleaned them up and used spade connectors to replace the molex connector since it was melted for my main power wires on the lower right connector (Blue, Black/Red, Etc). Since then I noticed that they corroded again and the terminals broke right off.
Is it possible to replace the fuse box altogeher? If so, how difficult of a task is it? Are there connectors on the back of the fuse box or would I be cutting wires and splicing the new fuse box in? If anyone has any pictures of the back of the fuse box that would be great. Also I am looking for a fuse box now I guess! Msg me if ya have one, i will also be looking in the Parts section. Thank you in advance!
Subyluver '92 Subaru SVX Ebony 216k miles (Magnaflow Custom Cat-Back, ES Stablizer Bushings, Permacool Relocator, 2.5RS FPR, SS Brake Lines, EBC Green Pads, Raceconcepts D/S Rotors, Pirelli P-Zero Nero M&S) (To-do list Koni Struts & Springs lacking funds) |
Re: Subaru SVX Fuse Box
Should just be a few plugs. A good alternative to new is a good wrecking yard unit..... a little research could save you some coin. I bet you can find one in the used parts section.
