Old 03-08-2010, 03:40 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Re: You might want to check the alternator/pwr steering idler pulley
Originally Posted by immortal_suby View Post
I'm interested in pics of this. Curious to see how they riveted a bearing in place.
The bearing itself is not riveted. The bearing inserts into the pulley from one side, and then there is a round plate that covers it and is riveted to the pulley, containing the bearing inside, between the plate and the pulley. These rivets would have to be removed in order to remove the plate and get the bearing out. I’ll take some pics when I get a chance, as it's likely that my description makes no sense to anyone but me.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 03-08-2010, 05:53 PM
Coan's Avatar
Alleged User
As promised, here are the pics. You can see in the first picture, the plate that's riveted onto the pulley, holding the bearing in place.
So, if you have this same pulley, you would need to do one of the following:
A) Drill out the old rivets, replace both the bearing and the rivets
or
B) Replace the whole pulley assembly
I chose to do the whole pulley rather than messing with the rivets, it's just a lot less of a hassle to me.
File Type: jpg pwr strng tensioner pulley 004 (Small).jpg (39.7 KB, 216 views)
File Type: jpg pwr strng tensioner pulley 005 (Small).jpg (37.2 KB, 212 views)
Jon
