#61
Re: carbon fiber driveshaft
What is the source of the vibration? Lack of a dampener? No center bearing? Small diameter?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 07-16-2008 at 02:42 AM. |
#62
<<What is the source of the vibration? Lack of a dampener? No center bearing? Small diameter? >>
being one piece, the universal will be at a real angle to fit. that means alot of stress on it. it will wear uneven and eventually fail. |
#63
Good to know. As of today I'm no longer going this route. The shop is just not up to it. They refuse to make a 2 piece.
#64
Is the angle too extrem only for manual SVX's or for automatic too ?
Nightmare is the name of the car... |
#65
It's the same, just a slight difference in length.
#66
I would have posted this earlier, but I don’t get on this site that often. I had an aluminum drive shaft made about three years ago. It has a slightly larger diameter (compared to stock) for strength reasons. This also meant that the heat shield had to be modified so that it wouldn’t rub (in addition to being a “one-piece”). For all of the reasons mentioned in this thread I put the stock driveshaft back on about two week after installing it. Vibrations were noticeable around 60-80 mph. It is lighter but I never weighed it. I never noticed much of a change in acceleration if any at all.
#67
in order for the D/S to work it would need significantly larger U-joint which means a fully custom shaft and joints... also means BIG money. I have toyed with the idea of having my D/S shop make me one for my silver... but the stocker has been fine so when I need a beefier one I will have it made
Tom |
