Old 05-30-2007, 11:04 PM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Unhappy Burning Rubber Smell?
Probably a stupid question for which I should know the answer, but why would a burning rubber smell be coming from my rear passenger side wheel? It coincides with the red break lamp warning light coming on sometimes when I break, particularly around a corner. Is it the rotor or something else?
“Veni, Vidi, Vici.”
Old 05-31-2007, 05:38 AM
dcarrb dcarrb is offline
The STOP LAMP warning light informs when a bulb is blown. If it doesn't illuminate every time you step on the brake pedal, there must be some other fault in the system. It doesn't have anything to do with the mechanical workings of the brakes.
dcb
Old 05-31-2007, 07:16 AM
svx_commuter's Avatar
Oh I do get worried when I smell rubber burning.
The brake light in my SVX comes on when the level is low in the fluid reservoir. It is an easy check and fix.
Smelling anything out of the ordinary gets me nervous. How does any smell get in the SVX?
It has to come thru the air supply system to the cabin by way of the grate under the wiper blades. Well if the windows are closed and the a/c is on. If it does not come in from outside then it has to be in the cabin.
Ruber does not smell electrical er ah as in burning wire insulation which is the one smell I always wait for to go away and then say GREAT it was some one else in front of me
Rubber smell? Can it be you are taking the corners at a good clip and the front is doing a little understeer??? Then you would smell the tires sliding.
Maybe one of the engine belts is a little loose......... Easy check too !!
How's the clearance to the back of the crank pulley where it would rub on plastic T-belt cover?
Take care,
John
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-31-2007, 10:44 AM
JaySVX's Avatar
JaySVX JaySVX is offline
A brake line leak onto the hot rotor can cause that smell. Check around to make sure there's no "extra" fluid under the car or on the rear axel.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-31-2007, 01:41 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
I sometimes smell gas. With my old '92 (not the one I have now) I smelled burning rubber and heard noise right before the timing belt blew. Anywayz any burning smell does make me nervous.
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 05-31-2007, 04:23 PM
Darren's Avatar
Darren Darren is offline
Its not the smell you need to worry about, its the flames
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 06-01-2007, 05:33 AM
Yeah, earlier I locked-in on the fact that the light was coming on when the brakes are applied. If it's the BRAKE light and not the stop lamp indicator, definitely check the fluid level.
dcb
