Yet another Wheel "will it fit" question..
I'm looking at Enkei NTO3+M wheels. The spec's are below:
size: 18 width: 7.5 offset: 42 bolt patt: 5 x 114.3 bore: 72.6 here's a link to them. http://www.enkei.com/RacingSeriesSpecs/NTO3+M.html (the hyperblack ones) Thanks for your help. |
The numbers seem to indicate it will fit. Hub rings may need to be used though.
You'll need hubcentric rings, as the SVX hubs are 56.1 mm. You'll also want to check the distance from the rim's mounting face to the rear of the spokes to make sure the brake calipers don't hit the inner surface of the spokes - you'll need the back of the spokes to bow outward at least 5/8" until they're at least 6 5/8 inches out from the center of the hub.
-Bill
thanks much. I'll email enkei, hopefully they'll respond..
Where the heck do I get a "hubcentric ring"? I assume it's something like a sleeve that fits over the hub to help center the wheel? |
Enkei might just supply them with the rims, if you ask for them up front. Otherwise, check Ebay. -Bill
Nice wheels. yes, they will fit, and yes you will need hubrings...but thats not a biggie, they can be had for about $15-20
-Best of luck!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
Thread Tools | |
Display Modes | |
