Old 06-25-2006, 06:06 PM
It's Just Eric's Avatar
Missing in action
Place to wire interior lights?
Hey there,
Recently I started on an interior lighting project. I stole the idea from the new mini coopers. I installed a green LED underneath each door handle, to gently illuminate it for idiot passengers to figure out how to get out of the car
I had originally wired them up to the shift indicator light in the center console, but for some reason Im blowing fuses. By adding the LED's Im not introducing any new current into the system, so Im mildly confused about this. Im just curious if theres a better / safer place to wire the lights before I go and make sure I dont have any crossed connections or shorts, which is quite likely being I did most of it at night
Thanks in advance,
-Eric BE AT THE NEW JERSEY MEET
R.I.P Cool Signature.
Old 08-08-2006, 03:58 PM
Missing in action
Okay, removed all the additional wiring and crap due to yet another interior swap out. Id like to pick back up on this if I can , so any feedback would be appreciated
Old 08-09-2006, 03:02 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
You know that you are supposed to put a resistor in series with each LED?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-09-2006, 07:31 AM
SubaSteevo's Avatar
No longer blue member
But I believe not having the resistor would cause the LED to burn out, not blow a fuse?
-Steve
01' MSM Lexus IS300
Old 08-10-2006, 06:53 PM
Missing in action
The LED's I purchased from radioshack have a resistor built in to the assembly. I had one lit but it was at the expense of my shift indicator. When I said "To hell with it" and wired both of them my gauge cluster lights went. So something really odd is going on there
Old 08-10-2006, 07:35 PM
immortal_suby's Avatar
Thread Killah
yes, clearly the svx anti-rice system is functioning properly.
Locker Link
2015 BRZ Limited 6MT
Old 08-11-2006, 07:48 AM
SubaSteevo's Avatar
Hahaha!
Actually I saw it in person, not ricey at all
-Steve
01' MSM Lexus IS300
Old 08-12-2006, 10:20 PM
Missing in action
The anti-rice system is working great actually. I have removed the white faced gauges, pulled off the damn spoiler, and am begining a repaint from the "Holy **** thats" barcelona red to the more subtle and classy black over swiss mica ruby. Also like to note the removal of an afr gauge that wasnt connected to anything,the removal of a wal-mart three in one misclenious "fits all ford pick up trucks" gauge trio, and the removal of a cd player that thought it was megatron. Also the slight interior upgrade going from L to LSI trim in progress, though that has nothing to do with rice.
So anyway, yeah, about that lighting...I know that I can hardwire it to the marker light, like my gauge cluster WAS, but thats the improper way to do it, and I would like to seek an alternitive
[/Rant ]
Last edited by It's Just Eric; 08-12-2006 at 10:36 PM. Reason: Forgot to add "I" to the last sentance.
Old 08-13-2006, 02:26 AM
Trevor's Avatar
Trevor Trevor is offline
[/Rant ]
It would appear that the OEM loom in your car must be one hell of a mess.
There is really no "proper" way to do it, other than connect to another circuit which is protected by a fuse and is energised, ignition, accessories, on/off or permanent supply as is required.
I see nothing wrong in using the marker light circuit, particularly if this has already been cut into. No point in damaging more wiring. In this case you are not adding a heavy current drain, which otherwise would be of concern, resulting in a voltage drop in the circuit and possibly the fuse opening.
Trevor, New Zealand.
Old 08-13-2006, 04:29 PM
Missing in action
You aint kiddin. Good thing I keep switching interiors, gives me alot of chances to replace "Improved" wiring harnesses with unbastardized ones. I probly will tap into the marker circuit, as the white faced gauges, as horrible looking as they were, actually worked fine.
