Old 06-21-2006, 10:34 AM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
Mixing mobil 1 and other oils.
Just wondering if any of you mix Mobil 1 Synthetic with other non-synth oils.
Last time I did 5:1.3 ratio just to get rid of a bottle of non-mobil 10w-30.
I was told this would dilute the gunk chomping strenght of M1. Mobil claims you can mix synth with non-synth too.
Opinions appreciated.
Adrian
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
Old 06-21-2006, 10:54 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
you have created a sythetic blend.... its perfectly fine just dont expect the same "performance" out of the motor oil
- John
Old 06-21-2006, 12:15 PM
Mr. Pockets's Avatar
Moderator
I have no idea what the above is supposed to mean, but I doubt you'll have any kind of problems.
I would, however, recommend picking an oil and sticking with it.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-21-2006, 12:20 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Agreed with the other guys. No harm but, stick with one oil and keep the extra quarts around. I personally use Royal Purple on my SVX and M1 on my GFs Focus. I have an extra quart of each. The claim about Royal Purple increasing gas milage is correct. I gained about 1.5 miles per gallon since my last oil change.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 06-22-2006, 09:30 AM
STORMINORMAN STORMINORMAN is offline
Nothing "wrong" with making your own semi-syn
I would recommend staying within the same manufacturer (i.e., mixing M1 with other Mobil oils) and staying "close" as far as API classifications are concerned (i.e., OK to mix SL & SM grades, a bit chancier to try to get max performance out of SF mixed with SM: too much of a swing, IMHO). OK to mix different weights, too, but you don't get a "new, improved weight" in your engine: what you do get is a proportunate mix of the different molecules, which may not be a bad thing.
Not that this kind of mixture will actually hurt your engine: just that "you can't make a silk purse out of a sow's ear". The SF oil will not magically become SL (or SM) by adding some M1. The modern API grades all say they are backwards compatible in their specs. Just don't ever use oil that pre-dates the spec for whatever engine you are running. No SA non-detergent from Autozone in your SVX, please!
I have had no problems with a winter mix of 50/50 Delo 15W-40 and Cheveron Supreme 10W-30 in one of my older Mercedes V8's. back in the "old days" my dealer used to put a 50/50 mix of synthetic & dino 10W-30 in my SVX for no extra charge as part of my "lube for life" program.
That was pretty sweet: 1/2 synthetic OCI every 3K for $0.00.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
