Old 06-05-2006, 03:32 PM
r85rx7
is the trunk lid height adjustable?
I'm looking to buy an svx and i went and looked at one today. while i was doing a walk around checking it out i noticed that the driver side of the hatch was not flush, it was higher than the passanger side. so basically is somthing bent or can it be adjusted?
Old 06-05-2006, 03:46 PM
Earthworm's Avatar
Meow!
I would assume you are referring to the trunk lid. I too would like to know an answer to this because mine is the opposite. (The passenger side sticks up a bit at the frontmost part)
Old 06-05-2006, 04:28 PM
r85rx7
yea its the trunk lid.
Old 06-06-2006, 02:54 AM
craftylandshark craftylandshark is offline
i don't know if this is common or not, but on mine, the rear wiper arm tends to sag below where it should sit a bit while the trunk is open. i've almost closed the tip of it (which is on the drivers' side) in the trunk two or three times. if it was ever closed on the wiper arm, i guess that could conceivably stress the hinge enough to leave that side of the trunk lid slightly higher...?
Kevin Crutchfield
Neophyte SVXer
92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying
92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's
Old 06-06-2006, 11:02 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
At least your rear wiper works. That's one thing on my vehicle i haven't taken care of yet, everything else is working fine (KNOCK ON WOOD). Purchased a rear wiper motor but was told that wasn't the problem. Next will be the rear wiper relay to see if that'll do it.....
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-06-2006, 12:11 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
yes it is adjustable all body parts are.... just takes a little hammering... there could be bolts that you can loosen and slide around but im not sure eather way i would take it to a body shop they shouldnt charge to much for this one
- John
Old 06-06-2006, 01:50 PM
dcarrb dcarrb is offline
If I were checking-out an SVX and noticed misaligned body panels I'd sure look closely to rule-out collision damage. In the case of the trunk, at the least it's a safe bet somebody tried to slam the lid on an oversized load.
dcb
Old 06-06-2006, 10:44 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
The trunklid is fiberglass/SMC. It does not bend permanently.
Though trying to shut it on a oversize load could tweak the hinges and/or latch.
Get a couple of body shims and you'll have it all good in no time.
'20 Honda Ridgeline
http://www.x35design.com
Old 06-07-2006, 04:18 AM
r85rx7
thanks for the help guys
