Old 03-13-2006, 09:58 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
BBQed feet
My car is toasting my feet. There's searing hot air coming in somewhere near the gas pedal. The foot area heats up enough that I can wear sandals in winter w/o turning on the heat, but I'll burn my toes if I hold my foot in the hovering position above the gas pedal. Now I've got a red burn on my toes and I'm a bit concerned about where that heat's coming from and if it's hot enough to toast my car? Any clue why this is happening and what I should do about it?
Still in love with my Subie
Old 03-14-2006, 12:01 AM
Probably the tranny!
Old 03-14-2006, 12:15 AM
nope. Turn on the climate control and turn the temp down. Then shut the climate control off. This should stop the hat air from flowing in
Old 03-14-2006, 02:21 AM
Alycone's Avatar
The last time my climate control was on it was set for 65, can it go lower? My tranny temp gauge is showing the usual, nothing alarming. The toasted feet thing has been going on for a month or two, gradually getting more noticable.
Old 03-14-2006, 09:41 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I'd see a good foot doctor and put some lotion on them thangs
1995 Subaru Svx L / AWD
Old 03-14-2006, 10:24 AM
n00b on demand's Avatar
just hit the "circ" button....that should take care of it
Old 03-14-2006, 10:45 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Same thing happens to me and this is what I do..
Brian
Old 03-14-2006, 11:21 AM
kinda off topic, but my heat only comes under the dash and vents by the windshield. should the heat also be coming from the vents near the radio and what not?
Old 03-14-2006, 11:34 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Subaru decided we only needed cool air coming out of the dash vents, A/C or outside air, no heat.
Dan
Old 03-14-2006, 11:55 PM
no
Old 03-15-2006, 10:06 PM
It's Just Eric's Avatar
Missing in action
The warm feet thing is fixable. Wear really, really heat reflective shoes. Or, you can fiddle with the climate control. I usually hit circ, vent, or turn it to a cold setting and turning it off. Usually thatll fix it
R.I.P Cool Signature.
Old 03-19-2006, 03:31 PM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
if you are running your air on auto does heat still come out of the bottom vents?
Old 03-19-2006, 09:47 PM
<<<Alcyone
You live in Sunny So Cal, you don't know anything about heaters . . .
If you're set to auto or economy, the ducting will change from dash vents (cooling) to floor vents (heating) as needed.
Dan
Old 03-19-2006, 10:32 PM
i know, i was trying to say turn the a/c on auto to see if anything is coming out of the bottom, vents it sounds like the heater might be stuck on, like the door is not shutting in the vent
