Old 02-23-2006, 02:32 PM
jsteele22 jsteele22 is offline
Plastic timing cover : Same as EJ22 ?
Okay so I went and looked at an EG33 at a salvage yard. It looked complete and in good shape (although dirty...). The one thing missing is the driver side timing belt cover (black plastic). I'm just wondering if I can snag one from the ubiquitous EJ22; thats supposed to be the same engine minus a pair of jugs, right ?
Old 02-23-2006, 02:37 PM
The eg33 was built from the ground up at least 4 times before production.
It is highly unlikely this piece will be swapable.
Old 02-23-2006, 02:48 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I'm thinking all EJ22's have one cam per side, so that would eliminate that. Maybe???? a cover off of a Dual Cam EJ-25????
I think I have a set of half decent front covers already pulled. If your interested, send me a PM.
Old 03-11-2006, 01:10 AM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
the pullies of the eg33 are longer than the pullys of the ej25, i gave my friend a couple of pullys for his ej25 buggy and they barely fit behind the timing cover, but all of the pullys are in the same place, basically point being is you would probably have to replace all three front covers if you went with the ej25 covers because they are not as big as the eg33 covers
Old 03-11-2006, 10:20 AM
If that's the case then it won't fit because the pulleys would rub the cover. There is not much clearance as it is.
