Old 03-08-2006, 04:30 PM
Jvan Jvan is offline
Question wrx silver parking light bulb
Would the silver tinted parking/ turn signal bulb from the WRX work in the SVX? That bulb is clear with a silver coating that turns orange when lite. When off, you can barely see the bulb thru the white lens. I did a search but couldn't find the bulb number only the OEM part number for the SVX.
Old 03-08-2006, 04:33 PM
Earthworm's Avatar
Meow!
If it's an 1157 then it will work.
I believe one person is already using these in the JDM clear corners with the internal orange globe removed.
Old 03-08-2006, 04:42 PM
michael's Avatar
michael michael is offline
What Potholes ???
It's me! It's me! It works just fine.
Wanted: Steering Wheel
Old 03-08-2006, 05:00 PM
is it a simple mater of relacing the old bulb with the new? Is theold bulb 1157 and the newone the same number or different?
Old 03-08-2006, 05:16 PM
Earthworm's Avatar
Meow!
The stock bulb is 1157NA (NA = amber)
Old 03-09-2006, 09:40 AM
Question
I was told that the WRX bulb is a 1156. I don't know the difference between 1156 and 1157 but Michael said it worked fine. Just alittle expensive to try without knowing for sure. Michael could you check the number on the bulb that you used.
Old 03-09-2006, 11:58 AM
Earthworm's Avatar
Meow!
the 1156 is only on/off (1 filament) just like our rear rurn signals. The 1157 has high/low (2 filaments) settings.
Old 03-09-2006, 12:04 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
The 1156 is a single filiment and the 1157 is a dual for parking and brake.
The WRXs use an 1156 in the front, the SVX uses an 1157. The 1156 and 1157 are not interchangable. You can grind off a tab to make it fit, but it will short the parking and turn signals circuits together.
The bulbs you want are the 1157s. You can get them here: http://www.pelicanparts.com/catalog/...STEALT_pg3.htm
or
http://www.xenonmods.com/silverbulbs...57bulbinfo.htm
They are pricey but you can create your own by taking a 1157A bulb and covering it with a thin layer of Testors # 1181 Aluminum model paint.
Disclaimer - I have never done business with either place listed in the links. Use standard web caution if you choose to do business with them.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 03-10-2006, 07:17 PM
Question
were do you get the paint?
