Old 11-25-2005, 01:11 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by guynoir
okay. It's been running on 89 for two years.
2006 Steel Gray WRX TR (sold)
Old 11-25-2005, 04:42 PM
KCROGUEDOG
i would first change fuel filter located in the engine bay on drivers side (black canister) around $25. i noticed a difference changing this when i got my ride. do you get check engine codes. if so go get it hooked up to a computer and have them tell you and show u the codes. easy way to find issues with these cars. i just had a bad coil pack and my gas milage blew. same as yours.
Old 11-25-2005, 07:24 PM
It takes a while for the car to know that you are giving it 93 again. I would use 93, and not mix the 89 and 93.
Old 11-26-2005, 11:38 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Originally Posted by Chiketkd
Take it easy, chike.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 11-26-2005, 11:57 AM
SSSVX's Avatar
Smile Welcome!
Welcome to the network. I did mention this site to your dad before? Now you know, pple here are so friendly and helpful....
I believe I know who you are based on your first post. Do you live off van voorhis road? Is your SVX blue color? You study at WVU and your dad work for WVU? If all these match, I'm pretty sure I'm right.
For the gas mileages you posted, I don't think it's that bad in Morgantown, in my opinions. This is home of mountaineers, so many hills. I average both of my SVXes 12-14mpg in town, with 93 gas. My engines don't have any problem. No wonder, that's one time I drove your dad's svx, I felt it didn't have so much "zoom" as mine? 89? No-no!
For your acceleration, I ain't sure. Do more search and you will find out more. The very last time (long time) I started the svx for your dad, I remember that was the power 16 blinks code. Do you know you have the tranny cooler installed on your car after the tranny was rebuilt one or two yrs ago?
In my opinions, SVX is a good car if you know how to treat it right. It's more special and unique than others, if you treat it right, it will serve you good. If you go to JohnHoward dealer and get it checked, they might charge you alot. There's one Suby shop in milesground, very nearby JohnHoward, they work on Subarus and some SVXes. Ask around and I am sure you can find them.
If you need more help, let us know.
Take care.
-SSSVX
Old 11-26-2005, 03:36 PM
oab_au oab_au is offline
I suspect that my SVX has some problems. It is a 1994 model, front wheel drive. We had it repaired a while back, but since then, I've noticed that the acceleration isn't as good as it used to be, and the fuel consumption is pretty bad. On a full fillup of 13 gallons, I'm getting about 200 miles, and this is in the city and I'm not a very wasteful driver. Especially coming from stops, sometimes the rpms will just go out of control, going up to 4k, but the acceleration will be pretty lousy. We have a toyota previa van, 4 cylinder, and I think that it has better acceleration than my SVX 6 cylinder. Acceleration is fine once the car gets up to speed, but coming from stops it's pretty lousy. So, in short, it's acting like a 4 cylinder car and it's consuming fuel like a 6 cylinder. Any idea what it might be?
Personally I don't think the low octain would do it.
It would appear that the transmision has problems. The reving to 4k on start up, depending what gear it is in at the time, spells either the forward clutch is slipping, or the brake band is slipping. Does the Power light flash on start up?
One Arm Bloke.
Tell it like it is!
Old 11-27-2005, 11:34 AM
SSSVX's Avatar
So I have hit it right on the nail ehh. PM replied to you. I think you should find a place that knows more about this car and work on it.
-SSSVX
Old 11-27-2005, 09:46 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Would the ECU learn faster if it was reset by pulling the battery cable?
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-28-2005, 12:12 PM
red95svx
Especially coming from stops, sometimes the rpms will just go out of control, going up to 4k, but the acceleration will be pretty lousy. ?
Two words: Bad Transmission
This is exactly what my 94 did. It's slipping. Eventually you'll lose a gear or two, and then it will crap out altogether. And stop being cheap with the gas!!
Old 11-28-2005, 12:49 PM
dcarrb dcarrb is offline
I gotta tell y'all, I fill-up with 93 octane and top-off at 1/2 (89 octane) to 3/4 tank (87), and I drive my SVX daily and keep comprehensive fuel consumption records, and there's no difference in fuel economy that would be measurable outside a laboratory setting, since when I ran straight premium.
The perception that premium fuel is somehow "better" is simply wrong. It's just higher in octane. It's foolish to spend more on 93 octane when the car will run beautifully on a mix that approximates 91. Those two extra octane points are money out the tailpipe.
dcb
Old 11-29-2005, 09:16 AM
red95svx
Originally Posted by dcarrb
It's foolish to spend more on 93 octane when the car will run beautifully on a mix that approximates 91. Those two extra octane points are money out the tailpipe.dcb
I agree. As long as you have at least 91 octane you're fine.
Old 12-02-2005, 07:26 PM
dromano's Avatar
dromano dromano is offline
O2 sensors
If you decide to replace the O2 sensors, do a Google search, I found Bosch sensors for a lot less than $100 per. The difference in performance is quite noticable. Changing O2 sensors is a basic procedure, the tuff part for me was disconecting the wire conection.
2012 Outback 3.6R Limited!
