Old 11-29-2005, 07:23 AM
Norm
Door Lock Switch
I have a 92 LSl that I want to add the power door lock switch thats found in the later models. I have a shifter trim plate that has the hole in it for the switch and need to know how to wire it up. Any help would be appreciated!
Norm
Old 12-01-2005, 06:22 PM
Best bet would be to go to a shop that install power door locks. for $149 you could get it installed and have auto start too boot.
Old 12-01-2005, 07:28 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
you can easily do it with any switch. I, and I'm sure you, would prefer the stock door lock switch. Regardless all you have to do is feed negative to two wires at the door lock timer on the passenger side. I believe the wires are accessable behind the passenger kick panel or up high in the passenger kick panel area....two orange wires. Give one ground for unlock, the other ground for lock.
Very simple.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 12-02-2005, 03:05 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
You only have to ground the wire that locks the driver's door. When you do that the driver's door will lock and that will automatically lock the passenger door.
Does anybody know if the door lock timer on US models is the same unit as JDM? If so then you could connect the speed sensor wire and have the doors autolock at 12mph.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
