What is the lowest offset that has been used with 8 inch wheels?
I'm trying to get wheels that will work on both of my cars, and I"m trying to figure out what offset works with both.
The eclipse likes a 38 or so offset, the svx likes a 48.... whats the lowest the SVX can go before they start rubbing on the inside of the spring.
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
Aan 8" rim w/48mm offset will already stick out about 1/2" (or 13mm) more than stock.
See how much room you have to play with on your car as not all SVX's are the same. (A tire may rub on one SVX but not on another)
Mr. Greg,
I believe Mr. Chike and Mr. SVXRide both use the 3rd Gen RX-7 rims, which are 8" wide with a 50mm offset. I don't think either one of them has said their tires rub....
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
The 18x8's I'm selling are 42mm offset, and I've had no problems what-so-ever on my old 94, or my current 96. There's no difference in how far they stick out either...atleast no difference perceptible to the naked eye.
[/COLOR][/COLOR]-Scott My Locker 2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14 2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14 1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65 1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07 1994 Pearl White LSi Bought: 2001? Sold: 2004? |
-Chike
Its going to depend also on what width tires you use. If you go with 235s or wider, good chance you'll need at least a 45 mm offset.
Does anyone on here have 8 inch wide wheels with 235/45 tires??
I don't think the STi rotas will work because of the 48mm offset. I guess I don't really know if a spacer is "safe" or not. I don't understand why it wouldn't be, however the general consensus i've heard is not to put 48mm offset and a 10mm spacer on the eclipse, even though this seems like it would be the best option.
Hey Greg...is there something wrong with the DSM wheels? If you are looking for straight performance on that beast, I would recommend keeping stock wheels and really good rubber.
That way you could get whatever wheels you want for the SVX. I don't think that you are going to find a wheel that works *well* with both cars. Especially if it is for performance reasons.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
I think Tom's son's SVX is running 245/45-16s on stock rims without any problems. -Bill
Hey Greg,
Have you looked into getting some DSM 17" wheels? I know of a few sets for sale around here in Denver. Those should clear the 13" rotors. I think the 3G's have 17" wheels too..
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs. http://stickyvinylgraphics.com/ |
I tossed a set of stock EVO rims on my SVX briefly... they're 17x8 +38 IIRC. The rears rubbed a little on the fender, but that was easily fixed by removing the rear liner trim and rolling the fender a tiny bit.
So, they "fit", but I wouldn't go quite that far on a regular basis. With the right tires, you can probably get away w/ a 17x8 +42 on the SVX... but I'm not sure if that will work on the DSM.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
-Andrew (ps, Im using 225/40 rubber)
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
-Chike
