Old 02-22-2005, 08:05 PM
Khalil's Avatar
Khalil Khalil is offline
blah blah, blah.
Revs while shifting
Got my transmission rebuilt in December, no problems with it at all Execpt:
Someones while switching gears, it revs up a little while its inbetween gears (`500rpm). Should i take the car back to the tranny guys(1yearwarrenty)? Or is the problem electrical related?
It rarly happens.. About once every 3 drives...
thanks,
-Khalil
*1992 SVX Red. Now 100k and climbing
Tranny rebuilt @ 84k. Repaint @ 87k.
Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K.
Old 02-22-2005, 08:24 PM
lee lee is offline
when it happens, is it all the shift points, or just some (& which ones)?
Old 02-22-2005, 09:45 PM
Khalil's Avatar
blah blah, blah.
Couldn't really say, happens durring slower speeds so probably between 2nd and 3rd..
Possibly between 1-2..naw probably not...
im pretty sure its 2nd - 3rd gear.
-Khalil
Old 02-23-2005, 01:35 PM
Earthworm's Avatar
Meow!
Possible issues:
- TPS out of adjustment
- band brake out of adjustment
- worn clutch was not replaced
Old 02-23-2005, 02:23 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally posted by Earthworm
Possible issues:
Yeah, what David said.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-23-2005, 02:54 PM
lee lee is offline
ditto, ditto.
I would place least emphasis on the clutch - not as an expert opinion - just for some reason I think the weak clutch in the Subaru is the high clutch, which means you would first see slip in 3rd to 4th gear changes (or so I believe, but then again I believe in Santa Claus too).
The TPS check is easy and only requires a VOM and a safety pin.
The band adjustment requires only a 17 and 7mm wrench (but small hands, coupled with a contortionist background couldn't hurt. )
Old 02-23-2005, 03:55 PM
n00b on demand's Avatar
What exactly does the TPS do?
Old 02-23-2005, 04:39 PM
lee lee is offline
it sends a varying voltage to the ECU, which interprets the information as to throttle opening and rate of change of the opening, i.e., you're flooring it.
The TCU takes the data and sets things like the POWER mode, and changes the shift map, adjusts pressure levels, etc.
