Old 02-16-2005, 10:55 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
thanks for the responds. i gain more knowledge.
of course i don't want to ruin the $400-$500 expensive tires that i put on. there's the reason why the expensive equipments at the tire stores can do a good job......
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-16-2005, 11:02 PM
SSSVX's Avatar
Originally posted by dcarrb
I've seen El Cheapo bubble-balance rigs in catalogs before (maybe Harbor Freight?), but, geez, man, proper high-speed balancing at most shops is a bargain. Why bother?
dcb
hey man, it's a bargain. i can do a mount-and-balance at a local tire shop for $9 per wheel (for our low profile tires)?? can we do it at wal-mart for cheaper?
hey, i figured that if we have 10 vehicles like earl or someone and if each vehicle needs to do balancing once every one or two month. if there's an ok alternative way, it's not a bad idea....
or if buy a high-tech spin balancer like around two thousands...if charge pple doing each for 5bucks, after doing 400 wheels the equipment will be free and can do it anytime you like at home...
-SSSVX
Old 02-16-2005, 11:03 PM
SSSVX's Avatar
Originally posted by mbtoloczko
That's amazing. I wouldn't have thought it was that accurate.
It's really, really amazing......how do you balance your tires? do it a couple times to make sure...??
-SSSVX
Old 02-16-2005, 11:05 PM
SSSVX's Avatar
Originally posted by Earthworm
It's not going to be perfect but I've never had to re-balance any tire I've ever done.
that's amazing. do all your tires always wear out evenly?
any pics for your oldy bubble balancer?
-SSSVX
Old 02-17-2005, 02:51 PM
Earthworm's Avatar
Meow!
I always triple check the balance once I attach the weights. Tires wear out fine but that's more due to the alignment. (I don't do alignments myself ) I've only had to change tires once from Canadian Tire Pacemarks (Bad) to Yoko AVS db s2's (Better).
I'll take a pic of the bubble balancer this weekend.
Old 02-19-2005, 12:28 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Originally posted by SilverSpear
you can't rely just on your naked eyes to make an alignment for your car, at least you need a measurement tape and a leveler... then the issue is probable...
What if you have averaged more than four alignments/day, five days/week (actually I worked six days/wk for 26 years) for the past thirty-five years. More than 36,000? I think I can safely say I can come pretty close with my naked eye, but for exact accuracy I still use the machine.
Like Harvey stated, the wider the tire/wheel combo, the less effective static balancing becomes. Mental exercise: place a stick on another, forming a 'T'. Add a weight to each end of the 'T'. When the stick with the weight is spun everything is good. Move one weight above the end of the stick and the other below. Now spin the stick and watch how centrifugal force pulls each weight to the outside, causing the stick to wobble. That's dynamic imbalance and there is absolutely no way to balance that with a bubble balancer or a nail in the wall.
Unless you have some very cheap (not necessarily inexpensive) tires, or are accident/puncture prone, they shouldn't require re-balancing more than once or twice in their lifetime. Ditto with alignments, worn parts, physically bending parts from potholes, accidents, etc. or sagging springs (which usually takes more time than the average set of tires will last) are about the only reasons for the alignment to change. Or the last tech to do it left an adjustment loose...
Old 02-19-2005, 03:32 PM
oab_au oab_au is offline
Yeh, good example Beav, I couldn't think of an easy way to demonstrate it. That does it well.
One Arm Bloke.
Tell it like it is!
Old 02-21-2005, 06:21 AM
Man you said it, you are an expert in wheel balancing!!! but what about the other members? the thing can be done if you know what things the adjust in the suspension... but not everybody can do it...
for me spending $20 for an alignment is far better from having the pain to do it myself...
Old 02-22-2005, 06:36 PM
Beav's Avatar
Not as old as Randy
35 years ago we got $14.95 for a front alignment. These days a four wheel alignment will set you back $50-$75. Still a bargain considering the price of tires, gas and being able to hold your beer with one hand and the cell phone with the other with the car going straight down the expressway during rush hour.
Old 02-23-2005, 12:22 AM
Your problem in the states is Labor Costs and you have a good economy... over here labor has become cheap and our economy is deteriorating... i said $20 for a wheel alignment job, this is the most expensive garage for this job, i can do it for a minimum of $7... an engine rebuilt costs no more than $500....
