Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 01-13-2005, 12:05 PM
cbx-man cbx-man is offline
New Turbo Ideas!
I was watching "Two Guys Garage" and they featured a new turbo set-up that locates the turbine/compressor in the BACK of the car. They say that with the increased distance from the engine to the turbo, everthing runs cooler; turbine is cooler thus transfers less heat to the intake air, and you don't cook the oil either. They also claim there is no additional turbo-lag since it is a positive displacement(?) system since the whole thing is pressurized.
There is more info on these sites. Check them out!
http://www.twoguysgarage.com/thisweek/
http://www.ststurbo.com/
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 01-13-2005, 12:29 PM
Earthworm's Avatar
Meow!
Actually if you search you will find at least 2 other threads about this style turbo.
Old 01-13-2005, 01:57 PM
mbtoloczko's Avatar
sans SVX
There is gonna be some turbo lag. Not only is there going to be lag on the compressor side, but there will also be lag on the turbine side.
Mychailo
Visit my locker
Old 01-13-2005, 06:57 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
yeah i started one of those threads.
did they dyno it before and after?!
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 01-14-2005, 12:57 PM
Wreckless
While this method might work with smaller turbos and larger engines, the efficiency losses make this seriously infeasable for smaller engines and any kind of decently sized turbo.
The colder exhaust due to the distance from the engine and the huge length of boost piping required will murder turbo efficiency and create a ton of lag over a properly configured turbocharger setup.
Old 01-14-2005, 06:36 PM
And you can say this with your spindle hanging out for all the world to see?
Old 01-15-2005, 06:32 AM
Myxalplyx's Avatar
Myxalplyx Myxalplyx is offline
XT6 is SVX's Daddy
Send a message via ICQ to Myxalplyx Send a message via AIM to Myxalplyx Send a message via Yahoo to Myxalplyx
Then you could design this in such a way to offset the deficiencies. One thing that could be done is to reduce the piping diameter between the exhaust port of the cylinder heads and the turbo. You could start off the diameter a certain width than keep reducing it until you get to the turbo. Using a ball bearing turbo will help with quicker spool up. Also using header wrap will help keep in the heat energy. All these things could be used together to keep exhaust gas velocity up and reduce or eliminate turbo lag.
Kevin Thomas
1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph
1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph
1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph
***R.I.P***
2010 RAV4 AWD Sport (13.717 @ 99.19mph )
2015 Honda Fit LX CVT (15.2 @ 90mph)
