Old 11-28-2003, 12:12 PM
ajb
Trunk release
Anyone out there who has some tips for diagnosing and fixing a broken trunk release cable?
Old 11-28-2003, 12:36 PM
Bobb Bobb is offline
Trunk lock
Hi AJB, Are you sure its the cable? Put your rear seatback down and crawl into the trunk with a light and see if the defeat awitch has gotten moved. Or, use your master key in the trunk lock. If that does not work it might just be frozen from non use. Of course it could be the cable. If it is, your on your own. I've not heard of problems with the cable, but have had little deals as mentioned above. Take care, BOBB P/S Maybe someone who has had the cable break will pitch in. "B"
Old 11-28-2003, 02:01 PM
lee lee is offline
I haven't had the cable break, but BOBB's suggestions sound on target.
if it is the cable, you will have to take off the plastic threshold at the drivers door, remove the back seat to get off the driver's side rear passenger side panel, then a trunk side panel and after getting the trunk open somehow, run a new cable following the path the current one uses - seen after all that other stuff has been removed. I'd guess about 2 hours work without being too rushed. careful with the threshold, the rear side panel has two plastic "screws" that hold it in, one up high (need seat back folded down to see) and one under the seat bottom (gotta take it out to get to it; the trunk panel has those typical plugs that push in and grip, not too much of a worry there, but nothing should really take a lot of force to remove.
Old 11-28-2003, 03:24 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
My cable got stretched out, it hasn't irritated me enough to do anything about it yet.
It looks like it's in place, but when someone pulls the release it seems that the cable is about 1/8" to 1/4'' too long to engage.
Old 11-28-2003, 08:59 PM
Aly - we'll fix that at the maintenance meet!
Old 11-29-2003, 03:15 PM
Alycone's Avatar
Thank you!!
Old 11-29-2003, 04:25 PM
Lightbulb
A small suggestion:
When most people [including me! ] mention cable, they mean a complete new part, inner and outer. The "inner" part is the cable, contained in the shroud or sheath or scabbard, whatever you might like to call the "outer" part.
Generally the "inner" cable snaps, and the "outer" is OK. Why not investigate if you can fit a new "inner" cable without taking the car apart? Even if you had to buy a new complete cable, and cut one end off the "inner" so you can feed it through the old one in place? After soldering up the cut end of course.
Worth a try?
Old 01-06-2004, 09:37 PM
Alycone's Avatar
Don't I feel dumb, I was browsing through the manual on the ferry and I got to the part about the switch to defeat the trunk release mechanism. After moving that into the off position, my trunk opens fine.
Old 01-06-2004, 09:51 PM
I told you we would help you fix it. It just wasn't at the maintenance meet.
I know of a couple of cables that have stretched. You can use a lead fishing split shot and a set of pliers to crimp it on in front of the original one to take out the slack. Of course you can fix it the way Alycone did too!
Old 01-07-2004, 03:55 PM
oab_au oab_au is offline
How dumb is dumb??
Don't feel dumb, I spent a couple of hours trying to fix the release cable. Till my best girl said " thats this little lever here?"
"Oh thats a watisname," I said as I switched it back. Dumb Dumb.
One Arm Bloke.
Tell it like it is!
Old 01-07-2004, 11:45 PM
It is nice that we can all be honest about the dumb things we do! If we can't laugh at ourselves, life would be pretty boaring. This way we can laugh with you, not at you. Then again....
Old 01-08-2004, 04:44 AM
Alycone's Avatar
Oh, shove it up your exhaust tips.
Old 01-08-2004, 04:48 PM
man you lucked out.
something broke on mine. (big surprise right?)
crawled into the trunk and had to squeeze myself around my subs to find anything. i couldnt use the key because the lock was frozen, AND its just tempermental.
had to use a crooked screwdriver to flip the unlocking switch, but i found after getting some deicer and a new key that it wasnt even locked.
i had someone move the release lever and i looked inside the latch and one of the thingies doesnt move.
is that a sign of a broken cable?
it still makes the 'thunk' noise it always did when it worked.
Old 01-08-2004, 06:53 PM
