Old 09-19-2007, 08:23 AM
Giugario Giugario is offline
need info on SVX rods
does anyone know is the eg33 rods are interchangeable with other subies'??
I really need to know, searched the forum without luck.
thanksss
Old 09-19-2007, 08:49 AM
Speedklix's Avatar
Locker Link Solution
Longassname (LAN) aka ECUTune is having them made for built engines
there is already atleast one SVX runnin them
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-19-2007, 08:53 AM
I want to get the carillos. I need to know which subies are interchangeable with the svx rods
Old 09-19-2007, 09:02 AM
Speedklix's Avatar
i think they started with eg22 rods... check the ecutune threads is what I'm getting at This sort of thing with "rods" and "ecutune"
I know I was gonna try eg22 when I was doing it alone... I'm gonna get them from LAN when I am ready to get back to it
-Mike
[SIGPIC][/SIGPIC]
Old 09-19-2007, 09:04 AM
thanks. will check it out
Old 09-19-2007, 09:07 AM
thanksss
Need for Speed will know, send him a PM.[Private Message]
Cool name you picked BTW. Spelling it the Spanish way is a stroke of genius.
Old 09-19-2007, 11:59 AM
Giugiaro Giugiaro is offline
boostin to the outer space
actually i also have dis one. can both be merged to become Giugiaro ??
The SVX expansion goes two ways:
1. Horizontal expansion: Multi SVXi
2. Vertical expansion: Fun max from one SVX
Old 09-19-2007, 01:36 PM
STI rods are the same along with the ej22 rods... Just go ahead and check the specs for the bores and length in your factory manuals
Old 09-19-2007, 02:01 PM
That's nice too.
You can keep 'em guessing!
Old 09-19-2007, 04:02 PM
Don't have a factory manual... any link?
bottom line, does the USDM STi rods fit instead of stock EG33 rods?
Old 09-19-2007, 04:55 PM
yes.... but since the SVX crank is internally balanced you would want a weight matched set of 6 not just any 6 you can find
Old 09-19-2007, 07:57 PM
longassname's Avatar
Just some dude.
are you in FL?
Old 09-20-2007, 01:22 AM
ok what should I be looking for? lighter rods? same weight?
Old 09-20-2007, 12:37 PM
Originally Posted by longassname View Post
are you in FL?
No, I am in Spain
Old 09-20-2007, 12:49 PM
Lighter, otherwise the stock rods with ARP bolts would be fine. Im telling you, you are best off getting the Eagle H-Beams that LAN has available
