Old 06-01-2004, 07:07 PM
immortal_suby's Avatar
Thread Killah
I checked the hose - it is nice and tight at both ends. I pulled it off and put it back on to make sure.
I also checked the connection a the MAF and wiggled it some - not sure exactly where you crimped it.
So far I still have the CEL.
Locker Link
2015 BRZ Limited 6MT
Old 06-02-2004, 02:47 AM
Question Could be real.
If you remember, my brother initially alerted me by saying that with TWO oxysensor codes, it was less likely to be a component failure, and more likely to be bad connection, or drawing air somewhere at the intake that it shouldn't.
I suspect my narrow fuel pressure reg vacuum pipe was the culprit. However, there were a number of other things I also tightened up, you may want to check those before you part with cash for devices:
There is an earth connection for the loom to the MAF connected to the bulkhead below the wires. I took it off, cleaned and tightened it.
The rubber hoses from the airbox to the camshaft covers, loose also, I tightened them with hose clips. Also any other pipe that felt loose.
These rubber hoses connect to a straight-through hard plastic pipe, seemingly plastic welded to the airbox. At the left side, this was damaged, could have been drawing air, so I sealed it with plastic putty.
The connector to the MAF sensor, it has five female connections, four of them have wires connecting. Looking into it, you can tighten each connector a little with a needle nosed pliers. Don't over do it, not necessary and you could damage it.
My car is now runing very well, and no codes.
If all the above do not clear the codes for you, there are only two options left; bad connection/s to one or more device, or the devices are actually broken. And the ECU could be one of these faulty devices. You would have to drop the dashboard panel, and demount the ECU and TCU, then check voltages and resistance between the sensors and the computer.
No other way, I'm afraid.
Best of luck with the hunt.
PS I have done about 500kms now, every kind of driving, no codes, knock on wood.
