Old 05-17-2004, 11:19 AM
Warren C Warren C is offline
5 spd Conversion Parts - List/Cost/Value
I have a 92 SVX, slightly wrecked in front and was recentley offered
another one with a dead tranny.
I have also recently purchased the engine and tranny from a wrecked
Impreza 2.5RS and could get the rest of the parts to put the Impreza
5 spd into the SVX with dead tranny.
What all is needed for a 5 sp conversion. I need a list quickly as
the rest of the Impreza carcass will probably disappear soon.
What is the usual cost/value of the tranny and all the parts for the
conversion..??
Warren C.
Old 05-17-2004, 04:03 PM
svxsubaru1's Avatar
I did a cable trannie conversion so i may miss a few parts snece that trannie is hydralicly operated but heres a quick list.
Trannie/shifting linkage
matching rear diff
clutch/brake pedal assembley
flywheel and bolts unless you want to buy new ones.
All the hydralic clutch lines/ master cylinder
The sensors on the brake/clutch pedals
5spd starter
5spd tranie mount unless you want to make a completly costom one.
I may of missed a few but these are the main ones that i first came up with.
Old 05-18-2004, 01:51 AM
5 sped conv. parts- differential
Is the "matching differential" essential....?? or just depend on what final drive ratio you want.
Warren
Old 05-18-2004, 08:32 AM
mbtoloczko's Avatar
sans SVX
Only with the WRX tranny is it not necessary to change out the rear diff.
Mychailo
Visit my locker
