Old 05-10-2004, 10:12 PM
svxsubaru1's Avatar
Spec clutch slipping sometimes?
I converted my SVX to a legacy 90-94 5spd and used a spec stage 2 clutch. It origanly slipped horribley, 1/4 throttle in 2 would cause it to slip, then i was extremly gentle to it for the 500 mile break in period and it did not slip at all. I then raced a my friends 89 supra turbo up to 130 mph no slipping. Today after school, i pulled out onto a street and lanched farily hard it was raining and i thought i was spinning my tires because the engine reved up so, so i shifted to 2nd and it revved up agian, 3 rd same thing, then i babied it for about 1 min then floored it no problems at all, then i tried to launch from a stop in 3rd no problems. After i went home i took the car back out and tried to launch in 3rd agian with a little more slipping to get the car started, the clutch would not hold any power at all, it was slipping horribley. I let the clutch rest for 2 mins then floored it no problems. I thought it may of been related to the rain for some reason so i went home. Then i went to a place and was coming home and saw a STI the light i was waiting at turned green and i wanted to catch up so i did a harder than normal launch, i lanched probley at 2500 rpms, the clutch started to slip again in all gears with any real amount of power. So i caught up slowley to the STI, then the STi turened were i had to go so i follwed it and eventully raced it no slipping clutch. Any ideas whats wrong, it seems like when ever i slip the clutch to do a fairley hard launch it just starts to slip hooribley. Is some thing out of adjustment?
Old 05-10-2004, 11:17 PM
mbtoloczko's Avatar
sans SVX
If you have a '90-'94 Legacy tranny then its a cable-operated clutch? If so, then the pedal free play adjustment is pretty easy, and I'm sure you've done that. Unfortunately, that means something is wrong with the clutch. Could be oil on the clutch surfaces. Could be that the step-height on the flywheel is incorrect for that pressure plate and disc.
Mychailo
Visit my locker
Old 05-11-2004, 09:39 AM
svxsubaru1's Avatar
Whats the step height on the flywheel?
Old 05-11-2004, 10:00 AM
mbtoloczko's Avatar
sans SVX
I don't know what the correct value is for your pressure plate and flywheel. I recommend calling Spec to get the value intended for the stuff you're using.
Mychailo
Visit my locker
Old 05-12-2004, 09:48 AM
svxsubaru1's Avatar
What does the step height mean?
Old 05-12-2004, 11:19 AM
Green1995SVX
I have the spec stage 2. It has never slipped, but i've never launched the car with any force. It worked perfectly from the day i put it in, and i now have 10,000 miles on the conversion. No issues.
Mike
Old 05-12-2004, 11:48 AM
mbtoloczko's Avatar
sans SVX
The step height is the difference in height between the pressure plate mounting surface on the flywheel and the friction surface area on the flywheel. WRX flywheels have a step height of zero. I don't know what it is for other Subarus.
Mychailo
Visit my locker
Old 05-12-2004, 06:37 PM
strange179 strange179 is offline
Still a member
Send a message via ICQ to strange179 Send a message via AIM to strange179 Send a message via Yahoo to strange179
step height
The step height for my '92 n/a legacy flywheel was also zero.
Jay
Speed Safely
Subaru, All We'll Drive
Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07)
Laguna Blue '94 L about 130Kmi (I think) for parts, in storage
previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else)
previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed)
Black '89 XT6 5spd AWD (storage)
Old 05-14-2004, 09:53 AM
svxsubaru1's Avatar
I am pretty sure its 0 if i rember right. I called up spec and they said if i sent in my stage 2 they would send a stage 3 for free. I asked when i would have to send it in, and they said any time. They said that they wouldent be surprised if the clutch couldent handle the torq of the eg33 after it was burnt a little from a hard launch. I was launching the car agin and if i slip it at around 2500 rpms it wont burn up when i shift to 2nd.
Old 05-14-2004, 11:12 AM
mbtoloczko's Avatar
sans SVX
I'm not sure I'd believe what Spec said about the stage 2 not holding the power after a hard launch because I remember you saying that even from the very beginning, the clutch was slipping badly. And Mike hasn't had any problems with his Spec stage 2.
Mychailo
Visit my locker
Old 05-14-2004, 12:14 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Think you might've torched the flywheel with those hard launches? Might be a good idea to invest in a new one, or at least resurface the old one before you put a brand new clutch in.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-14-2004, 07:22 PM
Flogging the clutch.
I have allways had doubt, that the 4 cyl clutch would take the SVX torque. What dia. is it 9"? I reckon a larger dia, or a twin plate, would be needed, to take the sort of treatment that you are giving it.
Old 05-15-2004, 10:09 PM
svxsubaru1's Avatar
I usaly resurface the flywheel when i put in a new clutch, i really wasent launching that hard, ive done a couple of launcehs before that were about the same and the clutch never sliped before. I really dident let the clutch slip that much i pay very close attention to this, i never let the clutch slip for more than .5 secs, after launch.
