Old 05-06-2004, 09:31 PM
UT_SVX UT_SVX is offline
livin in AZ
Five speed wire Q's
I am using the small car DIY basic kit, and on the instructions for the TCU splicing(B13) the wires do not match the colors, so I'm just trying to clarify if the pin positions are the key to identifying the wire before I start cutting and FUBAR something. Thanks in advance for the help. Darren
"Stand up Strong, Feel the Pain! Till the Angels Sing"
Social Distortion
1992 LS-L Pearl White :Optima Red Top, Motorsports Warehouse drop springs and swaybar bushings, Race Concepts slotted and dimpled rotors ,SS brake lines,semi-metalic brake pads, 4.11 5 speed, STi short shifter and tranny mount, Exedy sport clutch, Kartboy shifter bushings, intake silencer removed, ECU Tune Stage 1 v4
Old 05-06-2004, 10:29 PM
tancred
Hey man, i wish i could help but once you get that all figured out, maybe i can pay you like 3k to do mine....lol...
Old 05-07-2004, 07:44 AM
mbtoloczko's Avatar
sans SVX
There should be two large plugs that attach to the 4EAT tranny. One is a 12 pin plug (B13), and the other is a 15 pin plug. If you've got the correct plug and have it oriented properly, then the pins indicated in the instructions are the correct pins. The colors stated in the SmallCar instructions match the colors that are listed in the '92 SVX factory service manual. If you happen to be looking at the plug on the tranny itself, the colors are different. On the tranny:
B13-9 = green/white
B13-10 = green
B13-11 = black/yellow
B13-12 = black/white
Mychailo
Visit my locker
Old 05-08-2004, 09:13 PM
livin in AZ
3 G's AND 2 cases of beer........Dustin consider it done
Thanks Mychailo
Darren
Social Distortion
