Old 05-04-2004, 10:12 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Ball Joint
Changing my passenger front lower ball joint this weekend. Any suggestions to make this project easier on myself?
TIA
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-04-2004, 10:40 AM
UniqueAngle
take it to someone that know what they're doing ... they'll have the tools for it. You'll also probably need an alignment once it's replaced.
~Brenda
Old 05-04-2004, 11:07 AM
mbtoloczko's Avatar
sans SVX
As I recall, a press/puller is not necessary, so the balljoints are pretty easy.
Mychailo
Visit my locker
Old 05-04-2004, 11:22 AM
Word to Yo Motha
Thats what I was hoping for. Thanks
Collin
1995 L AWD
Locker
Old 05-04-2004, 12:05 PM
Mr. Pockets's Avatar
Moderator
The lower ball joint is pretty easy to replace on an SVX. Three big-ass bolts hold it on to the a-arm and then one nut holds it onto the upright.
While you may not need any special tools, I think the right size pickle fork wold help a lot. The joint can be fused to the upright pretty seriously and some leverage makes the job easier.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 05-04-2004, 12:18 PM
Word to Yo Motha
It is just about falling out right now, so I don't think it will be too bad. I just hope I get it before it becomes a problem. I will just give it a bit of 'encouragement' with a pry bar.
Collin
1995 L AWD
Locker
Old 05-04-2004, 01:13 PM
Moderator
If it's actually loose in the upright (doubtful), then you're going to have problems because the new ball joint won't sit snugly in place. I think what's far more likely is that the ball joint itself is coming apart (so the looseness has nothing to do with how hard it will be to remove) and that you're going to have some difficulty getting it out of the upright.
Well, hey, try the pry bar. If that doesn't work, go get a fork.
2005 Outback
END OF LINE
Old 05-04-2004, 01:16 PM
mbtoloczko's Avatar
sans SVX
.... big-ass bolts....
Mychailo
Visit my locker
Old 05-04-2004, 02:01 PM
svx_commuter's Avatar
Everybody needs to BJ replacement once in awhile.
I like to dive into the groove with a wedge of some sort. A large screw as in driver works well and fit snugly into the slit of the lower knuckle. Of course the cross bolt has to be removed first and jack stands positioned under the frame are required. The lower control arm has to hang free. Just bang like heck on the wedge thing to spread the slit open and release the ball joint.
The lower control will be holding the joint up so you will need a bar and some muscle to push it down and get the BJ out.
I think the alignment will be close as ther is not much room for the joint to slide around in the bolt hole clearance but it always safer to get it checked.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-04-2004, 02:21 PM
Word to Yo Motha
Well I need a BJ right now!!!
This sounds like it will be a fun project. Anything requiring a person to 'bang like heck' has got to be fun.
Collin
1995 L AWD
Locker
Old 05-06-2004, 04:30 AM
The Molinator
BJ!
I just did my front ball joints (I decided to throw them in) when I did my front (Motorsportwarehouse.com) Drop Springs and Koni Inserts. THEY DO NOT DISTURB THE ALIGNMENT! I REPEAT! Yada Yada Yada! I had heard that they did, but the position of the BJ on either end (3 bolts or 1 retainer bolt) is NOT ADJUSTABLE! So don't worry. [On top of that, I replaced springs, shocks (inserts) AND BJ's, yet my front camber needed no adjustment when checked!]
You need to support (block of wood/hydraulic jack) the upright at a certain up/down position for untightening and removal/insertion of the three bolts. [The outer two bolt nuts (on top) will hit the upright (can't remove) while the strut is fully extended >> needs to be jacked up to undo those outer two bolts. When assembling, place all three bolts in position while strut is extended. Then tighten only inner (toward center of car) bolt/nut. Jack up strut until you can get outer two nuts onto their respective bolts (on top). This probably sounds confusing, but when you get at it, you'll see what I mean right away.] I estimate the time for the BJ swap to be 1 to 1 1/2 hours for both.
HAVE FUN!
Jim
Old 05-06-2004, 07:29 AM
Word to Yo Motha
Thanks for the advice Jim. I am going to be attacking this project after work tonight. Good to know an alignment isn't needed.
Collin
1995 L AWD
Locker
