Old 04-28-2004, 07:24 PM
Gary
Question ABS Relay ?
I am in need of some advise. About 6 weeks ago the ABS light came on. I replaced the relay and all was well until yesterday. The ABS light came on again. Replacing the relay again is not a problem. I would like to know if I have a more serious problem with the ABS circuit. I disconnected the main ABS fuse to avoid draining the battery. Any advise would be appreciated.
Old 04-29-2004, 08:31 AM
red95svx
Self diagnostic procedure
Gary,
Take your SVX for a spin around the block. Make sure you drive faster than 19 mph for at least a minute. When you park, don't turn the car off. Move the passenger seat forward and look for a small, loose piece of carpet near the outer seat rail. Lift up the flap and watch for a blinking light. Count the blinks (the blinks will repeat after a short pause). Go to the HOW TO section of this website and open the Brake folder. Inside that folder is another Brake folder. Here you will find info on what the blinks mean.
Old 04-29-2004, 12:31 PM
Cool !!! Someone is using the How-To Locker for something.
