Old 04-27-2004, 10:05 AM
zavikan zavikan is offline
rear lens disassembly
Ok, I did some searching, but was unable to find exactly what I was looking for...
I have the rear center light out of the car, and its sitting on my bathroom sink, I wish to dissassemble it, to remove the red bars across the back up lights, an the SUBARU insignia. What exactly do I need to do?
is there epoxy? heating involved?
Old 04-27-2004, 10:11 AM
svx_commuter's Avatar
This should be interesting. I have thought about doing the samething. However I remember reading that others have tried and said the name can't be removed.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 04-27-2004, 10:14 AM
searching
reading past posts, others have done it. But there arent any actual clear instructions for the disassembly.
Old 04-27-2004, 10:19 AM
SubaSteevo's Avatar
No longer blue member
Disassembly would be similar to the headlight disassembly, so try searching for that, there was a how-to on headlight disassembly in order to clean the lenses a while back.
Basically heat and pry is all you need to know. Name can be removed using a fine sandpaper.
-Steve
01' MSM Lexus IS300
Old 04-27-2004, 10:48 AM
Steve I did not know that the rear assembly was hooked togeather like the front but I was thinking. Have you seen any of these removed?
Old 04-27-2004, 10:54 AM
hmmm
the rear is under very different conditions then the front, as well as the fact that the bulbs dont have the same heat. I would think it would be quite different then the front.
Old 04-27-2004, 10:57 AM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
I did this to headlights on my old car.
put them in the oven for about 10 minutes on 250*F. Started prying them apart, then put them back in the oven for 5 more minutes and pryed them completely off.
I guess the procedure would be the same .....its actually easy ....low heat and keep an eye on em.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 04-27-2004, 11:13 AM
SubaSteevo's Avatar
Rob did it about 2 months ago and posted pics, he said he used a hairdryer and a flat head screw driver to pry it apart.
-Steve
01' MSM Lexus IS300
